lo-fi
AC clutch adjustment washers
Hello
These may not be available separately, but I figure it's worth an ask.
Under the AC clutch plate there are a set of precision ground washers of varying thickness. As the friction material wears, you can remove to compensate and stop the clutch slipping as it has quite a limited range of travel. The only way I can see to buy them is as a whole clutch kit, which isn't ideal. Any pointers - or indeed washers from scrap compressors - greatly appreciated.
Many thanks
Share this post
Link to post
Are they just regular-ish looking plain washers, but of precision thickness? What kind of diameter and thickness?
Have lathe and surface grinder in the play room ;)
Share this post
Link to post
