Gazzar Posted April 13, 2019 Share Posted April 13, 2019 I doubt it. It's too big/small. It's going to shrink/swell. The hamster will stick/fall off. 1 Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted May 10, 2020 Share Posted May 10, 2020 How are you getting on with the pump @Mo Murphy? I find myself considering changing my water pump when I do the timing belt as a preventative measure but fear I could end up in the same boat. The pump is an Airtex one that I fitted years ago and it’s done a couple of hundred thousand miles since then with no issues so far. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted May 10, 2020 Author Share Posted May 10, 2020 So far so good James, no leaks to date. HTH Mo Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted May 10, 2020 Share Posted May 10, 2020 Thanks. Given mine is working fine at the moment I think I’ll buy one, but keep it on the shelf and refit the Airtex one assuming all is well when I take it off. Fairly quick and easy to change if need be down the line. Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted May 10, 2020 Share Posted May 10, 2020 I saw that thread quite late. Once I bought a TD waterpump for my 200Tdi by accident. I found that the bolt circle of the holes on the pulley was smaller (or bigger. I can't remember). I adjusted it by filing the holes in the pulley oval. The pump worked and fitted perfectly Quote Link to comment Share on other sites More sharing options...
