lorca Posted March 30, 2019 Share Posted March 30, 2019 Is there a quick fix to repair sagging material-in the P38 only in the middle..... or do I have to replace and re fit a new one? Any clever tips appreciated. thank you Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted March 30, 2019 Share Posted March 30, 2019 Do you mean the roof lining or the drivers seat cushion? I can't help in either case, but someone else might be able to help if they had a little more detail. Regards Quote Link to comment Share on other sites More sharing options...
lorca Posted April 2, 2019 Author Share Posted April 2, 2019 yes the roof lining is sagging in the middle . still attached all around the edges so i am hoping for a quick fix...... Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted April 2, 2019 Share Posted April 2, 2019 You could possibly put a very small incision into the lining and insert a plastic straw off a can of penetrating fluid and attatch that to some spray adhesive I have used this method in the past and worked ok for me Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Escape Posted April 3, 2019 Share Posted April 3, 2019 If you're not bothered by the looks, staples work great and are a very easy way of reattaching the lining to the polyester inner roof. You could set out a proper pattern to get a chesterfield look if you really want. Filip 1 Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted April 3, 2019 Share Posted April 3, 2019 11 hours ago, Escape said: You could set out a proper pattern to get a chesterfield look if you really want. Excellent 😂 Quote Link to comment Share on other sites More sharing options...
lorca Posted April 6, 2019 Author Share Posted April 6, 2019 thank you.... Quote Link to comment Share on other sites More sharing options...
