Franmax Posted April 2, 2019 Share Posted April 2, 2019 Help, ( said in a Penelope Pitstop voice 😊) From 2nd to 3rd gear its slipping. Over-revs, so i take my foot off a little to reduce revs. Sometime she will go in to 3rd, sometimes it takes more revs to engage gear. Anyone any idea. ?. Othe gears seem to engage with no problem. Do i need to spend loadsa cash on a recon gearbox 😢 or hopefully it may be a simpler issue ??. Thanks chums for any advice.😊 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 3, 2019 Share Posted April 3, 2019 ATF level? Quote Link to comment Share on other sites More sharing options...
Mellbell Posted April 3, 2019 Share Posted April 3, 2019 You could try and chà nge the oil in gearbox but make sure you change the gearbox filter aswell.ebay have filters .dont go to land rover. 1 Quote Link to comment Share on other sites More sharing options...
Franmax Posted April 3, 2019 Author Share Posted April 3, 2019 Thanks both. Fluid level ok. I will try the filter and oil change. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted April 3, 2019 Share Posted April 3, 2019 Have a read on Ashcroft's site too....... 1 Quote Link to comment Share on other sites More sharing options...
Mudmonkey Posted April 3, 2019 Share Posted April 3, 2019 (edited) As above, change oil and filter but sometimes this can do more harm than good if the oil hasn't been changed for a long time. If that doesn't fix it its probably cheaper to take a punt at a few second hand gearboxes than send it away to be repaired, there's not a lot that is easily repaired in them at home either. http://www.cowdery.org.uk/zf.php Edited April 3, 2019 by Mudmonkey 1 Quote Link to comment Share on other sites More sharing options...
Franmax Posted April 3, 2019 Author Share Posted April 3, 2019 Thanks madmonkey 😊 Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted April 4, 2019 Share Posted April 4, 2019 Another vote for oil and filter change - mine (TD5 though)Â had similar symptoms and a double oil/filter change brought it back to normal and it's still going strong.. Â 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 4, 2019 Share Posted April 4, 2019 If the fluid is black, you are unlikely to get it back, it should be a nice bright red colour ideally. Is your kickdown cable connected and adjusted properly? 1 Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted April 4, 2019 Share Posted April 4, 2019 1 hour ago, Bowie69 said: If the fluid is black, you are unlikely to get it back, it should be a nice bright red colour ideally. Is your kickdown cable connected and adjusted properly? Good point, mine wasn't black - but then neither was it cherry red... It was a sort of "brown with tiny black specks" colour 1 Quote Link to comment Share on other sites More sharing options...
Franmax Posted April 7, 2019 Author Share Posted April 7, 2019 Thanks all. Will try all of the above 🙇😉 Quote Link to comment Share on other sites More sharing options...
