ThreeSheds
Engine crane, electric winch, Tirfor or something else?
I wouldn't say it's going to make it any worse. IMO I like everything to be just so, bolts in a sensibly sized hole etc, but with LRs you need that extra bit of room around it.
Share this post
Link to post
No real difference to be honest, both would be putting them in shear, *if* it moved.
Share this post
Link to post
Starting to look the part...
  • Like 2
Share this post
Link to post
I used old beer crates and bits of wood, just kept lifting one end, then the other until it all lined up, then pushed it into place
Share this post
Link to post
I am abit late to the party and i'm glad you came up with a good solution which worked :)
I thought i would point out this little gem i came across not so long ago, it's a 500lb winch which works off a cordless drill.
Having lots of these drills about and various dodgy body parts, i find it a doddle to move stuff about
https://www.amazon.co.uk/Portable-500lb-Electric-Powered-Winch/dp/B07P7GH29G/ref=asc_df_B07P7GH29G/?tag=googshopuk-21&linkCode=df0&hvadid=310855477562&hvpos=1o1&hvnetw=g&hvrand=1694740625808202929&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1006978&hvtargid=pla-701276682937&psc=1
  • Like 2
Share this post
Link to post
Definately go with the 12mm bolts. I had a front towbar fitted to mine and managed to pull the top fixing bolts out of the chassis with the rotational force of pushing a trailer
Share this post
Link to post
