NeilF Posted April 13, 2019 Share Posted April 13, 2019 (edited) Last night, I turned the ignition off and the engine kept running, until I turned the headlights off??? It happened twice (I removed the key, the second time). The third time, I switched the lights off first, and then turned the key and the engine stopped normally. Is this odd behaviour? Edited April 13, 2019 by NeilF Quote Link to comment Share on other sites More sharing options...
sierrafery Posted April 13, 2019 Share Posted April 13, 2019 Off course it's odd but as long as you dont say what kind of Disco you have it'll be hard to make an ideea Quote Link to comment Share on other sites More sharing options...
Puffernutter Posted April 13, 2019 Share Posted April 13, 2019 Diesel I assume? In which case either a small diesel leak past the stop solenoid or a residual voltage on the stop solenoid. I had a Defender with a 200Tdi do the same! There was also another thread last year on the same topic. Cheers Peter Quote Link to comment Share on other sites More sharing options...
sierrafery Posted April 13, 2019 Share Posted April 13, 2019 Diesel can be a Td5 too which doesnt have a ''stop solenoid" and that symptom is caused by something else... so it's hard to say untill we dont know what year and engine is that vehicle Quote Link to comment Share on other sites More sharing options...
NeilF Posted April 14, 2019 Author Share Posted April 14, 2019 (edited) Sorry, away for the weekend, its a disco2 2002, TD5. I haven't tried it with the lights on since........ Edited April 14, 2019 by NeilF Quote Link to comment Share on other sites More sharing options...
sierrafery Posted April 14, 2019 Share Posted April 14, 2019 The first suspect is the interior fusebox which can develop various issues due to water ingress/internal corrosion. Quote Link to comment Share on other sites More sharing options...
