2a sump plug
2a-Egg
21 minutes ago, jordan_meakin said:
Lol!  Worth checking though!  You got it out?
Nope ended up going to a mates to help him clean off his series3 chassis and engine ready to roll it into a garage for an overhaul. Just tried again but its solid. Might have to gently tease it with an impact
32 minutes ago, jordan_meakin said:
Oh dear!  They're fairly robust so I can't imagine it'd snap but you never know with a Landy!  Remember a new copper washer when you put it back in.  I suppose, as the oil is coming out, there's no harm in a bit of heat to help it...
Already have the washer and a new sump seal sat waiting.. Just need it off... Flogging spanner might be worth a try
4 hours ago, Gazzar said:
Obviously, you will check why it was so tight? And replace the washer? 293959?
Already have the washer and new gasket.. Its still off at the moment, rear crankshadt seal needs replacing
