2a-Egg Posted April 13, 2019 Share Posted April 13, 2019 Looking at doing an oil change and want check if the sump plug is reverse threaded or not? Before I start tightening it in error. Cheers Adam Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 13, 2019 Share Posted April 13, 2019 Normal thread Quote Link to comment Share on other sites More sharing options...
2a-Egg Posted April 13, 2019 Author Share Posted April 13, 2019 11 minutes ago, Bowie69 said: Normal thread Okay im just weak then hahaha 😂 Quote Link to comment Share on other sites More sharing options...
jordan_meakin Posted April 13, 2019 Share Posted April 13, 2019 Lol! Worth checking though! You got it out? Quote Link to comment Share on other sites More sharing options...
2a-Egg Posted April 13, 2019 Author Share Posted April 13, 2019 21 minutes ago, jordan_meakin said: Lol! Worth checking though! You got it out? Nope ended up going to a mates to help him clean off his series3 chassis and engine ready to roll it into a garage for an overhaul. Just tried again but its solid. Might have to gently tease it with an impact Quote Link to comment Share on other sites More sharing options...
jordan_meakin Posted April 13, 2019 Share Posted April 13, 2019 Oh dear! They're fairly robust so I can't imagine it'd snap but you never know with a Landy! Remember a new copper washer when you put it back in. I suppose, as the oil is coming out, there's no harm in a bit of heat to help it... Quote Link to comment Share on other sites More sharing options...
2a-Egg Posted April 13, 2019 Author Share Posted April 13, 2019 32 minutes ago, jordan_meakin said: Oh dear! They're fairly robust so I can't imagine it'd snap but you never know with a Landy! Remember a new copper washer when you put it back in. I suppose, as the oil is coming out, there's no harm in a bit of heat to help it... Already have the washer and a new sump seal sat waiting.. Just need it off... Flogging spanner might be worth a try Quote Link to comment Share on other sites More sharing options...
DC_ Posted April 17, 2019 Share Posted April 17, 2019 Any luck? What are you using to get it off? Quote Link to comment Share on other sites More sharing options...
2a-Egg Posted April 17, 2019 Author Share Posted April 17, 2019 8 hours ago, DC_ said: Any luck? What are you using to get it off? Its off and used an impacted, was going to get a flogging spanner, but gently teased off with impact 1 Quote Link to comment Share on other sites More sharing options...
Arjan Posted April 18, 2019 Share Posted April 18, 2019 Well Done !! Quote Link to comment Share on other sites More sharing options...
Gazzar Posted April 18, 2019 Share Posted April 18, 2019 Obviously, you will check why it was so tight? And replace the washer? 293959? Quote Link to comment Share on other sites More sharing options...
2a-Egg Posted April 18, 2019 Author Share Posted April 18, 2019 4 hours ago, Gazzar said: Obviously, you will check why it was so tight? And replace the washer? 293959? Already have the washer and new gasket.. Its still off at the moment, rear crankshadt seal needs replacing Quote Link to comment Share on other sites More sharing options...
2a-Egg Posted April 18, 2019 Author Share Posted April 18, 2019 Just have to get the old seal/gasket off.. Quote Link to comment Share on other sites More sharing options...
