Larry C Posted April 15, 2019 Share Posted April 15, 2019 Can I get some possible causes and fixes. Thanks. 2000 110 deisel Quote Link to comment Share on other sites More sharing options...
western Posted April 15, 2019 Share Posted April 15, 2019 The Linkage from operating lever housing probably needs adjustment. Quote Link to comment Share on other sites More sharing options...
neil110 Posted April 15, 2019 Share Posted April 15, 2019 A possible alternative to the above is the position of the lever on the shaft. It will all make a lot more sense after you have removed the rubber gear lever gaiter and the sound deadening pad from the base of the levers Quote Link to comment Share on other sites More sharing options...
Farmerfred Posted April 15, 2019 Share Posted April 15, 2019 Two probabilities, warn selector or weak indent spring and ball on the selector shaft. There is the posibility that the lower end of the lever is bent not allowing it to engage properly. Quote Link to comment Share on other sites More sharing options...
