Ex Member Posted February 14, 2020 Share Posted February 14, 2020 (edited) Be aware that this gives a non-linear clutch feel. There is less force when depressed than at the top with a distinct transition. Personally, I don't like it. You get used to it, but a normal clutch with a slight increase in pressure with travel is easier to modulate. Edited February 14, 2020 by Red90 Quote Link to comment Share on other sites More sharing options...
Mark Bartolo Posted February 14, 2020 Share Posted February 14, 2020 (edited) 38 minutes ago, western said: Mine has been fitted since mid 1994, it was a genuine 300tdi clutch pedal assembly. I Would say there is another problem to make the spring snap. Mine is also a '94 300Tdi. I bought it 2 years ago and the original spring also snapped 8 months ago. I replaced it with the LOF spring, and that snapped yesterday. What could I be doing wrong? Edited February 14, 2020 by Mark Bartolo Quote Link to comment Share on other sites More sharing options...
western Posted February 14, 2020 Share Posted February 14, 2020 Does the pedal move easily on its pivot points, the can corrode & make the pedal stiff, doubt you would notice when moving the pedal with your foot, put some light oil on the 2 circular bosses & pin ends on each side of the pedal assembly & take the top cover off & work some oil or grease into the threaded rod & parts inside. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted February 14, 2020 Share Posted February 14, 2020 38 minutes ago, Mark Bartolo said: Mine is also a '94 300Tdi. I bought it 2 years ago and the original spring also snapped 8 months ago. I replaced it with the LOF spring, and that snapped yesterday. What could I be doing wrong? LOF reported the other day that they have been having issues. They just got in a new batch that they say solves the issue. I would contact them for a replacement. Quote Link to comment Share on other sites More sharing options...
Mark Bartolo Posted February 14, 2020 Share Posted February 14, 2020 40 minutes ago, western said: Does the pedal move easily on its pivot points, the can corrode & make the pedal stiff, doubt you would notice when moving the pedal with your foot, put some light oil on the 2 circular bosses & pin ends on each side of the pedal assembly & take the top cover off & work some oil or grease into the threaded rod & parts inside. Thanks for the tip. Quote Link to comment Share on other sites More sharing options...
Mark Bartolo Posted February 14, 2020 Share Posted February 14, 2020 21 minutes ago, Red90 said: LOF reported the other day that they have been having issues. They just got in a new batch that they say solves the issue. I would contact them for a replacement. Thanks for the info. Quote Link to comment Share on other sites More sharing options...
PIere Posted February 18, 2020 Share Posted February 18, 2020 I wonder if they will replace the earlier model FOC🤨 Quote Link to comment Share on other sites More sharing options...
