Jocklandjohn Posted April 21, 2019 Share Posted April 21, 2019 Tried search and not getting much guidance. Quickie - rear door hinge bolts on the body side - the top pair are with nuts, I can see them. the middle one - is it nuts or captive plate (or combination) the bottom - is it nuts or a captive plate? I have various furniture bolted inside that prevents me seeing the middle so need to dismantle that first, and bottom has a wing tank in the rear quarter so may need some jiggery-pokery to reach it, but would just like to know before I commit myself what I'm going to find. Quote Link to comment Share on other sites More sharing options...
western Posted April 21, 2019 Share Posted April 21, 2019 Upper & Lower hinge to body has Nuts on inside Centre hinge has 2 nuts captive to a plate. see items 10 & 11on page 798 of 110 parts book http://www.retroanaconda.com/landrover/parts_books/110/9_body_and_chassis_p741-909.pdf Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted April 21, 2019 Author Share Posted April 21, 2019 Excellent Ralph- thanks very much indeed. Just about to set to! 1 Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted April 22, 2019 Author Share Posted April 22, 2019 Update - hinges changed - bottom ones' nuts totally impossible to reach with the wing tank in place etc. So.....I removed the backdoor retaining arm (rear bottom left corner of door) and cut a small square of tub out to enable me to reach the back of the nuts with a spanner, then replaced and pop-riveted a cover plate back on with the retaining arm fastened to it - worth bearing this option in mind if any of you face a similar challenge! 1 Quote Link to comment Share on other sites More sharing options...
