lorca Posted April 21, 2019 Share Posted April 21, 2019 (edited) I have a 01 p38...recent buy. I parked it in a shopping centre and when i used the remote to open door it immobilised the jeep by picking up a signal from an ariel near by. It had to be taken by lorry to another location away from the other signal . It started up straight away.The recovery man told me to have it remapped {saudi } or to get a obd reader.....any advice would be great. thank you Edited April 21, 2019 by lorca Quote Link to comment Share on other sites More sharing options...
Escape Posted April 21, 2019 Share Posted April 21, 2019 Did you try to relock and unlock it with the key? That should work. Usually the problem with rogue signals is increased battery drain due to the BECM waking up all the time. You can disconnect the arial receiver or install a later type receiver that's less affected by other signals. But if the battery didn't drain and it's just the immobiliser not disengaging, you could simply have that turned off in the BECM. Filip Quote Link to comment Share on other sites More sharing options...
lorca Posted April 24, 2019 Author Share Posted April 24, 2019 On 4/21/2019 at 8:15 PM, Escape said: Did you try to relock and unlock it with the key? That should work. Usually the problem with rogue signals is increased battery drain due to the BECM waking up all the time. You can disconnect the arial receiver or install a later type receiver that's less affected by other signals. But if the battery didn't drain and it's just the immobiliser not disengaging, you could simply have that turned off in the BECM. Filip Quote Link to comment Share on other sites More sharing options...
lorca Posted April 24, 2019 Author Share Posted April 24, 2019 you could simply have that turned off in the BECM.......... how would i do that ? Quote Link to comment Share on other sites More sharing options...
Escape Posted April 24, 2019 Share Posted April 24, 2019 You need a Rovacom, Nanocom or similar to get into the BECM settings. Change immobiliser 'enabled' to 'disabled', and write the changed settings back to the BECM. But you do need diagnostic equipment... Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted April 25, 2019 Share Posted April 25, 2019 Why not just change the RF receiver to the later spec - YWY500170. Quote Link to comment Share on other sites More sharing options...
