Welding chassis
defender dinky
I disconnect the battery negative terminal out of habbit on my 110 when I weld even though the most complex electronic item is the alternator. When I used to work at an accident repair centre they used to clip a surge protector across the battery terminals.Ā
13 hours ago, defender dinky said:
I was more concerned about upsetting ecu's by removing battery leads and cutting power off to them. Dd
There is no problem at all in disconnecting the battery on a D2, you will have to reset the clock after,and maybe put the code back into the radio if it needs it. It won't forget any of its running settings in the BCU,instrument pack or SLABS ecu.
  • 4 weeks later...
Welded 100s of cars and never disconnect the battery
Ive welded exhausts with the engine running to make sure theres no leaksĀ  :)
Ive never had an electrical issue but did set fire to a sierra seatbelt when welding a sill once, that was a wee bit off a bonfire inside the door pillar
