Dan2100 Posted April 27, 2019 Share Posted April 27, 2019 Hi all I have a defender td5 manual and having problems with it, I also have a discovery with td5 automatic, would it be as simple as swooping engines over?? If I take engine out of discovery and put it in the defender would the injectors need re coding or would it run?? Any help would be very helpful thanks all dan Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted April 28, 2019 Share Posted April 28, 2019 What model are the TD5 engine as there are two: 10p and 15p. Yes, you would need to sort the injectors out. What's wrong with the existing engine? Steve Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted May 1, 2019 Share Posted May 1, 2019 engine will run without injector coding, otherwise is a relatively straight swap , Quote Link to comment Share on other sites More sharing options...
JohnnoK Posted May 3, 2019 Share Posted May 3, 2019 Swap the ECU with the engine, you will get the benefit of the better pull-away acceleration of the automatic engine's map. You may need to inform the BCM, though, I can't remember from where I read it. Nanocom should do it fine. Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted May 4, 2019 Share Posted May 4, 2019 19 hours ago, JohnnoK said: Swap the ECU with the engine, you will get the benefit of the better pull-away acceleration of the automatic engine's map. You may need to inform the BCM, though, I can't remember from where I read it. Nanocom should do it fine. It's not that simple,the engine ecu from the auto will put the engine management lamp on because it wont see the autobox ecu that it talks to in the Disco.(It may also make the temp gauge read wrongly) It will also need a security learn procedure to receive the correct code from the Defenders alarm ecu. Better to swop the engine over on its own and put the Defender injectors back in it,(If they are Ok) with new seals and washers. That way no diagnostic input is needed. Quote Link to comment Share on other sites More sharing options...
