Mutley Posted May 2, 2019 Share Posted May 2, 2019 I have a '95 300Tdi 90 and just lately when starting off in drive or reverse as i let the clutch out the motor seems to jump/lurch slightly!?! In all other gears u say it's fine only because i can up the revs a bit before engaging and disengaging the clutch. Any ideas, and please dont say clutch is on its way out? Cheers Andy Quote Link to comment Share on other sites More sharing options...
Yostumpy Posted May 2, 2019 Share Posted May 2, 2019 oil on the clutch from leaking oil seal, and / or rubber mountings old and perished. Quote Link to comment Share on other sites More sharing options...
Tanuki Posted May 2, 2019 Share Posted May 2, 2019 Check the handbrake cable - if it's binding and not allowing the shoes in the drum to retract fully it can cause a 'snatch' when first taking up drive. [I've seen a couple of cases where the handbrake cable has been melted - the inner nylon liner of the central core being swollen. This was because there was an engine-to-chassis earth problem and the starter-motor current had been going down the centre of the handbrake cable causing it to get hot and melt the liner] Quote Link to comment Share on other sites More sharing options...
Mutley Posted May 2, 2019 Author Share Posted May 2, 2019 Ok guys will check things mentioned on Monday when I'm off. @Yostumpy what rubber mountings? Cheers Andy Quote Link to comment Share on other sites More sharing options...
Yostumpy Posted May 2, 2019 Share Posted May 2, 2019 (edited) engine and gearbox, My old 110 used to do it, but that was a n/a ex- mil, fitted with an Isuzu lump. no evidence of oil leak, and only did it first thing, so I developed a 'bad' habit of pulling away in second, slipping the clutch a tad. (t box was changed for 1.4 btw). Edited May 2, 2019 by Yostumpy Quote Link to comment Share on other sites More sharing options...
