Cornish Rattler
Starting handle storage clips
That clip looks as though it might be useful; even better that it's available much cheaper for UK residents from Paddocks.
However, given the base vehicle is not a 101 or Lightweight, the clip being sought might be 90508035.
Share this post
Link to post
I don't find the little tool clips much use in all honesty.
The military stuff, as you can imagine, works great.
Share this post
Link to post
The MoD clips are very good, though I had to repair a damaged one on my Lightweight for it to work.  The simpler clips in David's photo are fine initially, but they loosen with age and need a bit of tweaking.  They're available in a range of sizes from most hardware shops and are not Land Rover specific.
Share this post
Link to post
On ‎5‎/‎3‎/‎2019 at 1:58 PM, FridgeFreezer said:
Saw a chap's 90 using a load of these mountings, looked very robust if a bit spendy:
Rubber over-centre mounting
You know what, they mite be better as I want them for fastening my small trolley jack bar and strong arm ( wheel nut remover ) to the rear wheel arch near the floor and I also want to install a dog guard with a piece of board fastened to it taking the same shape of the roof that I can fasten my metal detector, sand scoop and spade to and they look like they may do so I will order one and see if they will do ;)
Share this post
Link to post
