Defender 300 Tdi air filter house mounting
Please, tell me..
What part # / Part No's are involved to make this as I have the filter - but not the 2 clips and the rest..
Anybody has one perhaps ?
You have to buy them as a complete fitting Arjan and if I remember correctly there £30 each breakers would be your best bet if you have them in France , I’m at work at the moment but can get you the number when at home if no one else does . Then there’s a plate at the bottom and 4 of these rubber mounts err2337 . Hope this helps a bit.
Thank You !!
Breakers is here a problem - off to Holland next weekend and I'll try to visit one while over there. Otherwise it will be down do making one...
Part numbers are , and prices from Britcar
2 straps that hold the filter housing on ERR4688  £30 to £60
base plate that bolts to the head under 2 of the head bolts ERR2850  £30 to £70
supporting strap underneath ERR2851 £10  to £12
and the rubber mountings as above ERR2337.  from 60p to £9
a bit expensive I’ll take you a photo or 2 tomorrow but definitely make your own or get one from a breakers I’d say .
Will look into making something - breakers also want quite a bit of money for the shipping to France.
Perhaps in Holland next week..
Many thanks - this helps a lot !
I'd rather not undo the cylinderhead bolts to fit it there though..
However, I think there is plenty of space between the engine and the bulkhead for the filter to go...
Thank you !
" I might have put them on the wrong way round "
Not sure...
As they fit both ways this was obviously designed this way - LHD & RHD  versions perhaps ?
.... or to cater for the Monday morning assembly line mood...
You never know, do you...
This looks to me more practical
 Share
