JohnnoK Posted May 3, 2019 Share Posted May 3, 2019 My Disco2 Td5 has suddenly decided that going into reverse is too much effort without rolling the car back a bit first, which is obviously far from an ideal situation. The pedal is also spongy with the clutch taking just off the floor, no juddering or sudden "bite", just the spongy pedal and low actuation. I am going to change master and slave as a matter of routine, but I want to know if I should take a deep breath and budget for a clutch kit and DMF, too? Thanks! Quote Link to comment Share on other sites More sharing options...
bear Posted May 3, 2019 Share Posted May 3, 2019 Hi John, Due to the cost involved, if it where me, I'd bleed the clutch first hoping that fixes it. Regards, Griff Quote Link to comment Share on other sites More sharing options...
JohnnoK Posted May 6, 2019 Author Share Posted May 6, 2019 Griff, I will definitely be doing that first. I was just hoping to tap into the collective knowledge base to see if the prognosis should be good or could be dire... Quote Link to comment Share on other sites More sharing options...
