vstiebe Posted May 6, 2019 Share Posted May 6, 2019 Hello! I own a 1998 300 Tdi Defender 90. The analog clock gauge adjusment knob is only moving the minute needle. It is an AMR3443. Any tip or instructions on how to repair this gauge? It seems impossible to open it without breaking. When connected to the battery it works. I just can't adjust the hour needle. Quote Link to comment Share on other sites More sharing options...
Mutley Posted May 6, 2019 Share Posted May 6, 2019 When you push the centre button in gently turn it till it goes all the way in, it's like it has a locating pin that needs to find the correct slot. Just finely twiddle it till you feel it once in it kind of locks both hands to adjust the time. Well that's how mine is, i push the button in with x1 finger hold it in then turn it till it goes in again then adjust. May be worth a fiddle with? Otherwise i am no help sorry Andy Quote Link to comment Share on other sites More sharing options...
cackshifter Posted May 6, 2019 Share Posted May 6, 2019 Hi mine does just that. But I have found at some times it works ok. Try it at a different time, for me when the big hand is past 3 it works. Quote Link to comment Share on other sites More sharing options...
vstiebe Posted May 8, 2019 Author Share Posted May 8, 2019 Thanks for the replies! I will put it back on the dashboard to try at different hours. Or just wait to reconnect at the right time. Andy, I can feel the different click at various angles. But none locked the hour needle. Quote Link to comment Share on other sites More sharing options...
