Peaklander Posted May 6, 2019 Share Posted May 6, 2019 Please go easy on me for asking this just when I have competed repairs to the footwells on both sides of my 110. 😱 Does anyone know, definitively, if the A pillar foot can be removed from the rest of the pillar without the need to drill out any spot welds? I know that it is a tight fit up inside the bottom of the pillar but if I can, I should probably replace one of them. I will support the bulkhead, remove the M12 bolt and then try to drive the old foot out. It all depends on how it is fixed in, if at all. Does anyone know for certain?! Thanks Quote Link to comment Share on other sites More sharing options...
hurbie Posted May 6, 2019 Share Posted May 6, 2019 the foot is spotwelded to the door support , so you have to find the spotwelds and drill them out . Quote Link to comment Share on other sites More sharing options...
Peaklander Posted May 6, 2019 Author Share Posted May 6, 2019 Thanks. Is it just one or two? Have you replaced it yourself without renewing the pillar and if so, does it fit inside the pillar without any trouble? I'm wondering about this one from YRM link as I would trust their engineering dimensions. Quote Link to comment Share on other sites More sharing options...
hurbie Posted May 6, 2019 Share Posted May 6, 2019 i'm not sure how much spotwelds there are , but it could be more than 2 (my guese would be 8 or 10)Â just strip the paint of with a wire wheel and you will find the spotwelds. Quote Link to comment Share on other sites More sharing options...
Peaklander Posted May 6, 2019 Author Share Posted May 6, 2019 Thanks - I know how to find them but I have just painted the pillar so I am trying to gauge the job. Also I am wondering if it will hammer out without damaging the pillar. That's why I was asking if you (or anyone?) has done this job on its own? Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted May 6, 2019 Share Posted May 6, 2019 If you look in my rebuild thread Peaklander I replaced one on my bulkhead and I think I showed where all the spot welds were . Quote Link to comment Share on other sites More sharing options...
yalan Posted May 6, 2019 Share Posted May 6, 2019 (edited) Have fun.... it was x16 spots when I did mine. lots of photos on my site but this one just about shows typical locations. Bulkhead foot spot welds Bulkhead rebuild if I remember correctly, once the spotwelds are all removed it just fell away... but I did have footwell out at the time.. Edited May 6, 2019 by yalan Quote Link to comment Share on other sites More sharing options...
Peaklander Posted May 6, 2019 Author Share Posted May 6, 2019 Thanks guys. I’ll have a read. Quote Link to comment Share on other sites More sharing options...
Paul Brann Posted August 28, 2020 Share Posted August 28, 2020 Does anyone know for sure what the distance, centre to centre, is between the foot to chassis mounting bolts, I have seen 1510mm but the 'spare' bulkhead even though a little bashed at the foot, seems to be 1500 exactly . I want to make up a box section jig to be able to flip the whole bulkhead over to do the work, but need to be certain what the critical dimensions are - well subject to the usual Land Rover tolerances of plus or minus a football pitch Thanks Paul   Quote Link to comment Share on other sites More sharing options...
