Range Rover L322 Pads and disc renewal
Right,
I haven't seen a how too on here (prepared to be told wrong!) and so I thought I would do one. I have searched the web and found nearly all the info I need.
It has the larger brake calipers on the front beings its the 4.4 diesel V8. I've found conflicting information regarding caliper mounting bolt torque settings. The rears I believe are 65Nm, the front smaller sliding caliper is 110Nm and the larger front caliper is supposedly 275Nm. I just thought this was a bit high!
Any further info on this would be great. I am yet to try and download the RAVE stuff.
Steve
Steve,
Better off getting over to fullfatrr.com if you haven't been there already. All the knowledge you will need as it is dedicated to L322 and L405's.
The workshop manual is also on there if you know where to look. ;)
Edited by bishbosh
2 minutes ago, bishbosh said:
Steve,
Thanks
I might have to become a member......so I can find the workshop manual!
Steve
