mattD110td5x Posted May 12, 2019 Share Posted May 12, 2019 The centre consoles I've seen are all fairly wide, The mud one is much wider than the standard 1 DIN in a MY2000, maybe even 100mm wider? I'm looking for something thinner that will take a 2 DIN and that doesn't block the vents - In oztralia I use the vents a lot. I don't need 10 carling rocket launchers or six 50mm gauges, just a space for a 2 DIN car stereo. has anyone seen anything that is a bit more minimalist? - mattD110xtreme Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 12, 2019 Share Posted May 12, 2019 I think raptor make a narrow version. Quote Link to comment Share on other sites More sharing options...
western Posted May 12, 2019 Share Posted May 12, 2019 8 hours ago, landroversforever said: I think raptor make a narrow version. https://www.raptor-engineering.co.uk/product/defender-s111-double-din-console-dash/ Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 12, 2019 Share Posted May 12, 2019 The old Series centre switch panel could be widened with a flat panel in the middle, or the military ones I believe were wider anyway. Failing that, bash some tin, it's not a very hard shape to make. Quote Link to comment Share on other sites More sharing options...
mattD110td5x Posted May 14, 2019 Author Share Posted May 14, 2019 The raptor ones all look quite wide and would block the vents. Something like this one - can't workout where it comes from; Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 14, 2019 Share Posted May 14, 2019 Here's the military one - the angled ends are separate so the central panel is just a flat bit you could trim to any width within reason: https://www.ebay.co.uk/itm/254195611927 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted May 14, 2019 Share Posted May 14, 2019 Not exactly what you want, but if you cut the panel in half, you could squeeze a d din panel in, possibly?https://www.bits4landys.co.uk/series/dash/switch-panels.htm Quote Link to comment Share on other sites More sharing options...
