Hawklord
300TDI CV Joint spacer
Hi
Can someone confirm whether or not a spacer is required on the half shaft when fitting a CV joint to a 1994 300TDI defender 90.
Some web sites show part number TYF000010 in the assembly and some don't, some suppliers show the spacer in the kit diagram and some don't.
I changed the CV joint many years ago but don't think I used a spacer then but my memory isn't that good.
What is the purpose of the spacer and will it cause any problems if it should have one and I don't fit it or it shouldn't have one and I do fit it.
Confused ….
Share this post
Link to post
I would assume it is going on the early type I’ve got. Try the shaft in the CV without the clip, if it’s pushed all the way in, does the CV lock?
Share this post
Link to post
Thanks for your reply.
What do you mean by lock ?. With the shaft pushed all the way in the CV joint still moves in all directions.
The splined part of the CV measures 22mm and the shaft splined length up to the clip ring is 30mm meaning that there is 8mm 'spare' which happens to be the length of the spacer TYF000010. So am I right in thinking that the spacer should be fitted ?
Share this post
Link to post
This piece? (4)?
Share this post
Link to post
The halfshaft was redesigned for the Puma era and the spacer was deleted, which is why you're seeing different versions available.
Share this post
Link to post
Thanks all for your replies and by Westerns parts listing it should be on there as my chassis No is MA.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
