neilc Posted May 16, 2019 Share Posted May 16, 2019 I have just replaced the whole of my exhaust system , apart from the downpipe its been a breeze , however the downpipe seems to be smoking on first startup , its smells more like burning than exhaust fumes , there is nothing trapped in the joint , should I just loosen the 3 bolts and re-position and try to get a better seal or is there something im missing?. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 16, 2019 Share Posted May 16, 2019 Have you done many miles since swapping it? Its not just the coatings on the new bits burning? Quote Link to comment Share on other sites More sharing options...
neilc Posted May 16, 2019 Author Share Posted May 16, 2019 I haven't even moved it , I did wonder as there is no blow around the joint and I recall getting exhausts installed and garages and there being a small of burning initially , ill probably run it for a while and see if it burns off , as I say seems more like smoke than fumes. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 16, 2019 Share Posted May 16, 2019 Yeah I’d say it’s the coatings burning then. After I helped a mate with his kitcar exhaust wrap, that smoked like a steam engine for the first short drive Quote Link to comment Share on other sites More sharing options...
jordan_meakin Posted May 16, 2019 Share Posted May 16, 2019 I recently fitted a new one and experienced the same - give it a good run and check again. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 16, 2019 Share Posted May 16, 2019 Just oily handprints on the pipe are enough to smell bad for a while. Quote Link to comment Share on other sites More sharing options...
