P38 Paul Posted May 19, 2019 Share Posted May 19, 2019 Hi everyone hope you are all well , I have a problem with the interior courtesy lights on the car , when I open the drivers door they don't come on but they are still working when the passenger door is opened , I recon its the switch but where do I find it & can it be repaired ? PS , the new radiator is still ok 😉 Quote Link to comment Share on other sites More sharing options...
Escape Posted May 20, 2019 Share Posted May 20, 2019 There are microswitches in the lock assembly. One of those controls the courtesy lights, and they are know to fail. You can swap the entire lock, or try to repair/replace the switch. Not that easy to get to, especially if it's the first time. Filip Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted May 20, 2019 Author Share Posted May 20, 2019 3 hours ago, Escape said: There are microswitches in the lock assembly. One of those controls the courtesy lights, and they are know to fail. You can swap the entire lock, or try to repair/replace the switch. Not that easy to get to, especially if it's the first time. Filip Hi Filip , is that the lock assembly that is in the handle or the latch assembly , IE :- the latch half way down the side of the door ? Quote Link to comment Share on other sites More sharing options...
Escape Posted May 20, 2019 Share Posted May 20, 2019 The latch halfway down the door, the bolts are on the outside but it's quite a wiggle to get it out... Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted May 20, 2019 Author Share Posted May 20, 2019 17 minutes ago, Escape said: The latch halfway down the door, the bolts are on the outside but it's quite a wiggle to get it out... That's OK , I'm good at wigglin 😏 1 Quote Link to comment Share on other sites More sharing options...
