Delfree Posted May 20, 2019 Share Posted May 20, 2019 Hi I have recently bought a landrover freelander 2 td4 gs, 08/09. I have noticed what looks like an oil leak from the bottom grille where the intercooler is, is this a common thing to happen, you're help would much appreciated, thank you Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted May 20, 2019 Share Posted May 20, 2019 I can’t say if this is your problem without looking but .... to change the oil filter it’s a lot easier if you remove the air pipe that is in the way, when you re fit the old hose it’s a bit of a fiddle and after 10 years the pipes are often a bit crabby the oil in the pipes can leak out and that’s where they often drip. HTH Regards Paul Quote Link to comment Share on other sites More sharing options...
