300tdi top end gasket set - any experts on what goes where?
Hi,
I'm going to be doing a head gasket soon and have just received it and and top end gasket kit, both Elring make. I'm a little confused about some of the washers supplied with the kit though - I can identify the following; valve stem seals (8), injector seal washers (4), rocker cover washers (3) copper washers for temp sender and heater output (2 req though 3 smaller and 1 larger are present) (I think), rocker cover gasket and manifold gasket (obviously),  gasket for thermostat housing to head. I'm guessing the O-ring and maybe the steel washer are to go with the oil seperator thing that attatches to head?
I'm however a bit stumped with the 8 round  "ring" type copper seals that appear too big for anywhere (bottom right in picture), though initially spill rail to injectors but too large diam for that? Also the paper gasket that's oval shaped with three holes in it?
Last question, where the t/stat housing attaches to block with gasktet - should I be using some sort of sealing compound on this gasket or fitting it dry? Want to get it right first time as can't redo when head is fitted without stripping more parts off front of engine.
All help gratefully received.
Cheers,
Martin.
Edited by hxk494
additional info added
9 minutes ago, western said:
It's item 6 on page 238 in retro's 110 parts book 300tdi engine section http://www.retroanaconda.com/landrover/parts_books/110/3_engine_200TDI_300TDI_V8_p168-299.pdf
the other copper washer could be for turbo oil feed banjo bolt on same page item 3
that looks right. I shouldn't need them as I'm jsut planning to remove manifolds and ease back to allow head to come off, not undo any turbo feed/drain.
Any thougths on gasket to t/stat housing - sealant or dry?
