vinnie mc Posted June 1, 2019 Share Posted June 1, 2019 hi all firstly thanks for any help put forward its really appreciated , i have a 94 defender 200 tdi original ( 11l ) and unfortunately the rear cam bearing has slipped back leaving low oil pressure ( gutted ) , i realise its a big job but i am going to do the work myself which i know will take a while for me to do as i work full time and only have my garden to do the work in , my defender is my everyday work and social vehicle so i am wanting to get the engine out quickly and was hoping i might be able to drop another one in ie : disco 200tdi or a 300 tdi which i have seen some reasonably priced ones about , so my question is apart from another (11l) which are really expensive compared , what would anyone think might be the easiest engine to drop in ie : least amount of work converting things while i repair mine , once again thanks Quote Link to comment Share on other sites More sharing options...
hurbie Posted June 1, 2019 Share Posted June 1, 2019 my gues would be to drop a disco 200tdi in it , and swap the exhaust and intake manifolds from you defender 200tdi Quote Link to comment Share on other sites More sharing options...
Puffernutter Posted June 1, 2019 Share Posted June 1, 2019 I don't think either are particularly easy. Doesn't the 200TDi disco require a different exhaust? Cheers Peter Quote Link to comment Share on other sites More sharing options...
western Posted June 1, 2019 Share Posted June 1, 2019 Get a Disco 200tdi & use that block & internals, drop your existing cylinder head & manifolds, engine mounts,timing case on to it that way you don't have any problems changing exhaust/turbo. or strip existing engine & have the cam bearings replaced. 1 Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted June 1, 2019 Share Posted June 1, 2019 I did exactly as western suggested, changing the timing chest and ancillaries over to turn the disco (12L) into a defender (11L). Not the hardest thing to do but time consuming. Just remember to crack the crank pulley bolt before stripping the engine out...then you’ll only have to swear at removing the one from the donor engine Quote Link to comment Share on other sites More sharing options...
vinnie mc Posted June 2, 2019 Author Share Posted June 2, 2019 thanks for the advice lads i think thats the way ill go , change everything i need to onto a 12L , but now to work ,once again cheers 1 Quote Link to comment Share on other sites More sharing options...
vinnie mc Posted June 2, 2019 Author Share Posted June 2, 2019 thanks again lads , im new to this but hopefully will improve the more i use it which i think i will be with the work i have to do , ive been rummaging through the site and its great , im trying to find info on what i will have to change to the donor engine is it everything , thanks Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted June 2, 2019 Share Posted June 2, 2019 page 10, about half way down and you'll see the 11L stripped of its timing case and a list of the bits needing swapped. Quote Link to comment Share on other sites More sharing options...
vinnie mc Posted June 3, 2019 Author Share Posted June 3, 2019 6 hours ago, Scotts90 said: page 10, about half way down and you'll see the 11L stripped of its timing case and a list of the bits needing swapped. thanks scotts90 ill have a look after work cheers Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 3, 2019 Share Posted June 3, 2019 I did it too, as Scott says not difficult but time consuming. Mo Quote Link to comment Share on other sites More sharing options...
Snagger Posted June 3, 2019 Share Posted June 3, 2019 Don't forget the flywheel housing - I think it's different between the two models (stud pattern), so check before you try fitting the engine. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 3, 2019 Share Posted June 3, 2019 Don't forget to bolt through the flywheel housing into the ladder frame if you want to avoid a leaking rear seal and T seals. Mo Quote Link to comment Share on other sites More sharing options...
vinnie mc Posted June 4, 2019 Author Share Posted June 4, 2019 thanks again for the advice , does that mean that i will need a bellhouse conversion plate then Quote Link to comment Share on other sites More sharing options...
western Posted June 4, 2019 Share Posted June 4, 2019 No, just use the existing one from the 11L defender engine 1 Quote Link to comment Share on other sites More sharing options...
Pappa Smurf Posted June 7, 2019 Share Posted June 7, 2019 I've got a Disco 200tdi onto a standard lt77 that was bolted to my old 19j. All I did was buy an adaptor exhaust manifold off Ebay. Then my mechanic extended my pipework to fit onto the rad and intercooler from the Disco. The exhaust itself is a 200tdi straight pipe. The only other thing I had to do was to mount a custom bracket onto the right hand side of the engine for the airfilter box, extend the air intake pipe and fit an electric fan. 1 Quote Link to comment Share on other sites More sharing options...
