Sign in to follow this
Tirran
Yes another bulkhead question
I knew this Defender had significant corrosion when I bought it as I was looking for a project that would be a replacement chassis starting point. Stripping back my 1993 200tdi for a rebuild, the photo attached shows some of the rust damage seen so far.
Are there repair panels available for the section above the foot wells and below the vent panels or as I suspect this is a fabrication job?
Bill
Share this post
Link to post
As yet no one seems to produce an inner repair section for the vent and screen mount area. You get extended footwell sections that take you up to just under the fold, above that it's good old fashioned cardboard and sheet metal, combined with copious quantities of tea and swearing...with a bit of welding and grinding too.
Seen worse, repaired worse...as have many on here.
Share this post
Link to post
Thanks, as I suspected. In fact the section around the top corner and the heater matrix mount on the nearside is full of paper, poor filler and more corrosion.
Share this post
Link to post
