Cappo Posted June 7, 2019 Share Posted June 7, 2019 (edited) Hi all, I'm in the process of installing a 3.9i V8 from a Disco into my Defender, and the good news is that it's in and running! However this is just with the wiring nd ECU lying loose. I'm trying to decide on a permanent home for the ECU. Because it all came from a Disco, the ECU loom is not long enough to put it on the rear bulkhead (I think I read somewhere that the RRC loom is longer and allow this?) so I'm after suggestions for alternatives. Currently I'm looking at the battery box, or fabricating something to put it on top of the middle section of the seat box (under the cubby), or possibly on top of the trans tunnel - once I've made a new one up! I do remember seeing somewhere where someone had put it under the steering column but it feels a bit large for that. I'm also mindful of keeping it above wading depth, not that I do much of that but something to bear in mind I guess. If anyone has suggestions and/or pics that would be very helpful, thanks. Edited June 7, 2019 by Cappo Keyboard missing letters out! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 7, 2019 Share Posted June 7, 2019 You could always extend the loom. I put my ECU behind the dash, but that's a Megasquirt so it's a different shape/size. It used to be on the ceiling but I'm not planning on wading that deep these days. Quote Link to comment Share on other sites More sharing options...
mad_pete Posted June 8, 2019 Share Posted June 8, 2019 Mine went on the rear bulkhead and was from a rangie. Quote Link to comment Share on other sites More sharing options...
Adam001 Posted June 8, 2019 Share Posted June 8, 2019 I wondered this for my BMW ECU. I fitted mine behind my Mudstuff center console. But I've now moved it into the engine bay itself. I placed it in a sealed ABS box along with all the engine management related relays and fuses. It's located in front on the the heater box where it's well protected. Working well so far and de-clutters the cabin nicely. Quote Link to comment Share on other sites More sharing options...
