kevin50 Posted June 7, 2019 Share Posted June 7, 2019 1987 110 defender, its an ongoing rebuild, I bought it as rolling chassis, it had these discs on in photo, and the calipers were in a box of parts that came with it. Anyway rebuilt front axle with all new seals bearings ect. put same discs back on, the calipers seemed to fit at first but when both bolts are fully tightened up they are hitting hubs both sides, drivers is not to bad but passenger is just locking up. Cant work it out, as Im sure that both discs and calipers are both vented, there is no numbers on calipers to tell excactly what part they are. Anyone ant Ideas ?? this has really got me stumped. Quote Link to comment Share on other sites More sharing options...
MR-HIPPO Posted June 7, 2019 Share Posted June 7, 2019 (edited) When I rebuilt my axle, I had a spare pair of vented discs attached to hubs that were thinner than the hubs fitted my early (1989) axle. I had to swap the vented discs to my hubs to use them, it was lucky that I spotted this when I did as I nearly rebuilt the wrong hubs. IIRC later hubs (200tdi ish I think) are shorter (bearings closer together) than the early ones. I suspect that you have a mismatch of swivel housings / stub axles / hubs. I am sure that someone more knowledgeable than myself will be along shortly to clarify / correctly answer this. Edited June 7, 2019 by MR-HIPPO Quote Link to comment Share on other sites More sharing options...
western Posted June 7, 2019 Share Posted June 7, 2019 Do you know what the calipers/disc came off & the part numbers was it a later defender. ? my '89 110 has vented disc/calipers which Ifitted years ago, they don't touch the hubs, mine are STC1266 & STC1267 Calipers & FTC902 disc. wondering if your calipers are genuine or orignal calipers with a aftermarket spacer fitted. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted June 7, 2019 Share Posted June 7, 2019 Yes. This has been discussed before. Vented calipers on early hubs can hit each other. some people say they don't have the issue. Nobody seems to have figured out why. Western, can you look at yours and see how much clearance exists? Maybe take a picture. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 7, 2019 Share Posted June 7, 2019 No problem with vented calipers on my 90 with the earlier wider hubs. Are the calipers from a reputable brand or are they unbranded? If the tolerances are tight then a misshaped casting could cause a conflict. Quote Link to comment Share on other sites More sharing options...
western Posted June 7, 2019 Share Posted June 7, 2019 36 minutes ago, Red90 said: Yes. This has been discussed before. Vented calipers on early hubs can hit each other. some people say they don't have the issue. Nobody seems to have figured out why. Western, can you look at yours and see how much clearance exists? Maybe take a picture. I can IF its stops raining, as the front wheel has to come off. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted June 7, 2019 Share Posted June 7, 2019 No rush. It would be nice one day to figure this out. There must be some variable that is not obvious. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted June 7, 2019 Author Share Posted June 7, 2019 (edited) Thanks Previous Owner can only remember that he got them from Britpart, they told him that they were model correct whatever that means, cant remember part numbers and the calipers have no numbers stamped on them anywhere. I was thinking that Id made a mistake somewhere when rebuilding axle but really cant think where. Took some measuments tonight, distance from disc wall to hub is exactly the same all round both sides, diatance of middle is same also both sides. I have measured calipers for width, if they were a touch narrower they would fit, so now thinking I have wrong ones,/ well hoping its something as simple as that Don't suppose anyone has a spare caliper handy to measure width Edited June 7, 2019 by kevin50 forgot to add Quote Link to comment Share on other sites More sharing options...
western Posted June 7, 2019 Share Posted June 7, 2019 If weather is OK tomorrow I'll pop my drivers front wheel off & sort some photos & measurements Quote Link to comment Share on other sites More sharing options...
kevin50 Posted June 7, 2019 Author Share Posted June 7, 2019 34 minutes ago, western said: If weather is OK tomorrow I'll pop my drivers front wheel off & sort some photos & measurements Thanks Mate, Cant think what else it could be apart from Caliper. One thing is I think the original would have been Solid discs but the PO was going to convert to Vented, so maybe got wrong part numbers. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted June 7, 2019 Share Posted June 7, 2019 20 minutes ago, kevin50 said: Thanks Mate, Cant think what else it could be apart from Caliper. One thing is I think the original would have been Solid discs but the PO was going to convert to Vented, so maybe got wrong part numbers. Yes. They were never "meant" to have vented discs. Adding it is something people do, but it was never designed to work with them on purpose. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 8, 2019 Share Posted June 8, 2019 No clash with earlier wide hubs and Lockheed vented calipers on mine. Mo Quote Link to comment Share on other sites More sharing options...
Roverdrive Posted June 8, 2019 Share Posted June 8, 2019 I converted my 1997 110 to vented discs a few years ago - no issues. Nowhere near it at the moment, so can't take pictures, but I think they were allmakes calipers, with Britpart discs. Quote Link to comment Share on other sites More sharing options...
uninformed Posted June 8, 2019 Share Posted June 8, 2019 Sorry I can only add speculation at this point, or rather more confusion. But I did somewhat bolt up a early 110 front stub (wide bearing ) and matching hub with my 98 300Tdi 110 Vented rotor to the car itself ( 98 110) and it all seemed to line up and not foul. If I get time over the next week ill look into it further. All parts I have are genuine (except rotors) Serg Quote Link to comment Share on other sites More sharing options...
western Posted June 8, 2019 Share Posted June 8, 2019 Managed to whip the right front wheel off & took these photo's, my calipers are Lockheed items. Hubs are the original as built wide spaced bearing items 1 Quote Link to comment Share on other sites More sharing options...
kevin50 Posted June 8, 2019 Author Share Posted June 8, 2019 4 hours ago, western said: Managed towhip the right front wheel off & took these photo's, my calipers are Lockheed items. Hubs are the original as built wide spaced bearing items Thank You Very Much for that Mate, really appreciate you going out in the rain to do that. By looking at the gap in yours mine are only out by a couple of mil or so, but its still enough to stop them turning. Theirs no numbers on my calipers at all so not sure what part they are. they do look digferent to yours from the side, will take more pics of mine later. as for my hub Im sure its the original too, will try and get part numbers for which bearings I used, was not really aware that bearings were different either. Trying to work out the width of your caliper from your tape measure, will do same measurment as yours when I go up. Thanks Again will post later 1 Quote Link to comment Share on other sites More sharing options...
neil110 Posted June 8, 2019 Share Posted June 8, 2019 Back to the original photos of the calipers. Whereabouts are the bleed nipples on said calipers? Mine is a 1984 One_Ten. Originally fitted with solid discs. I managed to find a set of the spacers which go between the two halves of the caliper, fitted them and then fitted vented discs. During the intervening years I have changed hubs, stub axles and fitted a 300 Tdi front axle case. As it is now, it has the earlier BIG CV joints and early hubs/stubs etc. Point is, I don't think your calipers are 110 calipers. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted June 8, 2019 Author Share Posted June 8, 2019 43 minutes ago, neil110 said: Back to the original photos of the calipers. Whereabouts are the bleed nipples on said calipers? Mine is a 1984 One_Ten. Originally fitted with solid discs. I managed to find a set of the spacers which go between the two halves of the caliper, fitted them and then fitted vented discs. During the intervening years I have changed hubs, stub axles and fitted a 300 Tdi front axle case. As it is now, it has the earlier BIG CV joints and early hubs/stubs etc. Point is, I don't think your calipers are 110 calipers. Nor di I mate, found these pics from other day, you can see where bleed niples are. do they give you any idea of what they are ?? Quote Link to comment Share on other sites More sharing options...
western Posted June 8, 2019 Share Posted June 8, 2019 Single line calipers are 90/110 /Defender, two line were used on disco/RR. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted June 8, 2019 Author Share Posted June 8, 2019 1 minute ago, western said: Single line calipers are 90/110 /Defender, two line were used on disco/RR. What do you mean by single line Mate ? Quote Link to comment Share on other sites More sharing options...
western Posted June 8, 2019 Share Posted June 8, 2019 one brake[line] pipe to each caliper, wheras a Discovery for example has 2 pipes to each caliper. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted June 8, 2019 Author Share Posted June 8, 2019 3 hours ago, western said: one brake[line] pipe to each caliper, wheras a Discovery for example has 2 pipes to each caliper. So now Im back to thinking its probably the right caliper,😆The drivers side is only catching on one corner, the rest are free , its the passenger side that's worse, Had a wire brush on grinder on the corners where it is catching and its moving easier, that's how close it is, so will do a bit more tomorrow till its clear. Maybe its just a bad set of calipers cheap stuff., will post back tomorrow with results. Thanks Everyone for help, 1 Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted June 8, 2019 Share Posted June 8, 2019 Don't want to state the "bleedin" obvious...but that pic with the ratchet attached shows you have the caliper fitted upside down as I can just see the nipple cover at the bottom of the pic. The change in orientation may give you the very minimal clearance that there appears to be on Westerns pics. 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 8, 2019 Share Posted June 8, 2019 Have a cookie. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted June 8, 2019 Author Share Posted June 8, 2019 1 hour ago, Scotts90 said: Don't want to state the "bleedin" obvious...but that pic with the ratchet attached shows you have the caliper fitted upside down as I can just see the nipple cover at the bottom of the pic. The change in orientation may give you the very minimal clearance that there appears to be on Westerns pics. I know Mate, that was one of my first pics then realised turned them around and they were exactly the same. Quote Link to comment Share on other sites More sharing options...
