The inertia switch on the td5 loom does it need to be bridged? I’m not using an electric fuel pump as the 110 is mechanical just in case this is one of the reasons the starter won’t turn or immobiliser has kicked in
as I said before I’ll wait till I put engine back in and sort engine loom before I start to worry😂
Share this post
Link to post
The power to the ECU is linked to the inertia switch so as to kill the engine in the event of a crash, so yes it does need to be linked.
Share this post
Link to post
I don’t have an ecu or a gear box loom it’s a td5 loom in an 1986 110
no electric pump
Share this post
Link to post
Put the stop solenoid wire through it, it'll do a job then.
Mo
Share this post
Link to post
No there's no requirement to bridge it out. I have full XS td5 looms, including using as much of the td5 engine loom as possible. No inertia switch installed or bridged, on the td5 it feeds the ecu and fuel pump relay...as the tdi uses neither it serves no purpose.
Share this post
Link to post
