New wiring looms from Autosparks in 200TDI 110
5 minutes ago, MR-HIPPO said:
May not be a bad idea, if there is a 200TDI wiring diagram out there somewhere I would certainly like to get my hands on a copy.
I hope you get this fully sorted and properly up and running soon.
The Haynes manual I have is fairly accurate (but needs to be in colour...) drop me a PM etc
  • Like 1
Ok, first motorway test run for an hour.... nothing too serious to fix.... 😁
Coolant system needs bleeding, installed this system which beeps and flashes whenever air touches its sensor... so I know that’s working which is great
https://youtu.be/OHfD-BNPVcg
Also the Engine Watchdog system alarm told me I had half a litre too little oil in the engine by going off until filled it to neutral or just over, so again that seems to work well...
https://youtu.be/xHe-H0ul_Kk
However the heater won’t come on, believe I should have this running to bleed the coolant of air bubbles? The three wires seem correctly connected from the dash switch to the 3 wires on the side of the heater matrix, fuse seems ok, assume it’s the fuse with rectangle and 3 squiggly lines indicating hot idea? Waiting on the auto electrician to trace them electronically...
Are we missing anything heater wise?
Edited by roamingyak
3 wires to heater.
On the vehicle here they are
Green  (on the diagram above this is purple/green?)
Green/Yellow
Green/Slate
Any way the first wire is a fused live supply to the heater (Green or Purple/Green)
The other two wires will read live from the heater end, they earthed back through the slider switch on the dash.
The speed is determined by which wire is earthed through the dash switch.
I believe that the Green/Yellow connects to the heater motor through a resistor inside the heater box, and so when earthed via the dash switch gives the slower speed, whereas Green/ Slate is directly connected to the motor, and so when earthed  gives you full speed.
With all the wires appearing live at the heater, I would assume that the problem is almost certainly with the wiring at the switch. (You should have the G/Y G/S and an earth there)  Or the switch it's self may be faulty?
Glad to hear you are up and running, I bet the auto electrician will be glad to see the back of you.
EDIT: I have just watched the two videos in you above post, they both look like good bits of kit.
Edited by MR-HIPPO
  • Thanks 1
Ok thanks, will investigate tomorrow.
Us Southern Hemisphere people are a kind and generous bunch, they are trying to talk me into staying longer and doing some more work on the old girl :)
 I have a big area out the back out of the way and they are a nice group of people. Having a strange Landy Kiwi to chat with breaks up the working day it seems and the auto electrician has enjoyed the challenge - we installed an entire dual battery system (ctek) with solar panels, sound system and various things before attempting the Landy looms.
Ok, one annoying gremlin 😩
The engine oil light keeps coming on whilst driving. This tends to be after at last 10 minutes of driving from cold. My last test drive it repeatedly (7-8 times) came on when coasting in neutral - for example accelerating in forth gear, coming up to some lights, slip it into neutral, oil pressure light flickers on rapidly. When I accelerate again it goes off again.
The oil pressure sender unit (the thing under the oil filter) has been replaced with part number PRC6387G as well as the wiring on the new loom.
The wire from the Engine Watchdog unit was also plugged into the wire going from the sender to the dash light, but we disconnected this (we put a diode onto it at first, then disconnected it)
Any ideas please? We are pulling our hair out...
No, just the engine temperature. And it has an additional wire that taps into the oil pressure light wire, so you get an alarm from the engine watchdog as well as the normal dash light telling you there is low oil pressure.
Edit: I changed the engine oil and filters this morning, Castro’s Vectron 15-40 oil, genuine filters, no leaks after 50km. So same problem before and after oil change...
Edit 2: This may have been happening before, only two weeks ago we changed the oil pressure sender sensor below the oil filter and hadn’t driven it since. So may or may not be related to new loom and sensor install. From reading other posts it may be a leak in one of the gaskets around the turbo/exhaust area, did see a puff of smoke there a few weeks back....
7 minutes ago, Retroanaconda said:
Had the old oil pressure sensor failed? What was the reason for changing it?
The light wasn’t working, changing all of the loom wiring, so changed the oil pressure sensor as well. Clean slate.
I’ve ordered a new one again, maybe the fitted new one is faulty, fingers crossed.... to confirm, it just flickers, doesn’t stay on constantly....
Then will increase idle speed a touch to see what happens, plus make auto electrician double check everything. Then double check hoses, manifold gasket etc for leaks...
Other than that it could be the oil pump or serious engine components? Need to find a Landy specialist then I think...
Does that sound logical?
6 minutes ago, MR-HIPPO said:
As above, a pressure gauge would show what is actually happening.
To me, the fact that the oil light is only coming on while the engine is idling, after it has warmed up, does not bode well.
To confirm, it’s not at idle as in stationary, the vehicle is moving.
Engine idling though from your description . It could just be the tickover is too slow , which incidentally would suggest other slight issues( FIP timing or FIP condition) . An oil gauge even temporarily installed would answer with real numbers . If it is genuine low oil pressure I think I would start with removing  the oil filter mounting block and strip and give it a good clean.
cheers
Steve b
  • Thanks 1
15 hours ago, MR-HIPPO said:
I am now as confused as you are.
Only happens when I’m driving at speed, put into neutral with foot off clutch to coast up to some traffic lights, then the oil pressure light will flicker repeatedly at high velocity.
Does not happen when stopped in neutral.
Fairly sure this oil pressure light hasn’t been working for a while, so by fixing the electrics I now have the pleasure of seeing the light working :)
Going to replace the new oil pressure sensor today and then test the oil pressure with a machine rather relying on than the Landy electrics. Fingers crossed :)
  • 1 month later...
Would this help, it was given to me on another site as I tried to build my own loom........ TRIED, so bought a auto sparks main loom, rear harness and engine harness  for ease..... and it comes with no legend at all, hideous!
So back to the start for me but I have no loom to compare to..... so if any of you guys would like to earn £50 and tell me what all the wires are and where each wire goes where exactly, that would be great... I have managed to work some out by reading this post and by using the attached file... but I’m sure there is more wires than what’s on that file.
Also it’s very different to the partial one I built, and I had that start up on the key..... I’m almost at the point of taking a massive loss and selling the project because this is annoying me sooo much!
Edited by T0M
@T0M
Firstly welcome to the forums, you are in the right place to get this sorted.
The  diagram that you have shared looks to be the full colour version of the diagrams posted by PaulMC  earlier in this topic.
Those diagrams have a legend showing warning light functions, and wire colours, so by cross referencing with what you already have it should make a bit more sense.
668953_1991to1994-1.thumb.jpg.92fd099915
84452858_1991to1994-2.thumb.jpg.5922145b
If you are still stuck, I still have a 200TDI vehicle sat here for reference, and I am sure we can get you new looms all plugged in correctly.
Please feel free to post any farther questions here.
Hope this helps, and apologies for the late reply, Hippo.
  • Thanks 1
Welcome to the forum T0M
 How far have you got with it ? Do you have a multimeter to check volts or continuity ? The basic colours are much the same for this as earlier series 3 looms so studying an earlier diagram might help to familiarise yourself with basic circuit colours and a look at Terri-anns site gives you a list of function for colour including later Tdi systems .
As you work through it just ask on here as each query comes up , this forum is tech. based and no question is not worth asking :)
cheers
Steve b
  • Thanks 1
Wow thanks guys for the warm welcome much appreciated, sorry for the late reply I’m working nights at the moment.
So I have a bit of it worked out using the diagram. Engine loom is now in place and connected, the main harness is sitting in situ, but a couple of bits I can’t work out even with the diagram.... unfortunately not having the old one to compare too is taking its toll.
Off the main harness in the engine bay, I have the rear harness worked out, (but is it worth the hassle of getting it through the chassis?), I know which is the glow plug timer relay, as stated the engine loom is connected. That leaves me with;
1 block of four connections which has, 1 brown wire, 1 white wire, 1 white and black and 1 green wire to it.
1 block of five connections which has 1 white and orange, 1 purple and orange, 1 green, 1 white and 1 black
Then there is 2 black and white with male and female connectors, I’m thinking they go to the brake fluid
1 white and orange with a female connector.
Obviously the lights, horn, heater etc, I’ve worked out.
Blimey that’s a big list for now but any help at all will be most appreciated!!
Many thanks
Tom
to brake PDWA unit or low brake fluid float cap.
air condition feed 12v ignition switched
