roamingyak Posted June 13, 2019 Share Posted June 13, 2019 I’m looking to put in a new 65 amp alternator with my new 1994 200TDI wiring loom, being retro fitted to a 1991 200TDI. LRDirect list 2 Lucas models as STC234G.TR and STC234G.C8. Any idea what the difference is please? https://www.lrdirect.com/STC234-Alternator-A127-65Amp-Lucas-No.-242/?keep_https=yes Do they come with a pulley attached? Doesn’t look like it, if not what extra parts do I need to order please? Shipping to South Africans so keen to get it correct first time :) Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted June 13, 2019 Share Posted June 13, 2019 Surely LRDirect would be best placed to answer your query. Quote Link to comment Share on other sites More sharing options...
roamingyak Posted June 13, 2019 Author Share Posted June 13, 2019 Phoned and mailed them. They are really only interested in providing customer support when you’ve made an order etc, not on what a part number is etc Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 13, 2019 Share Posted June 13, 2019 In the past when I've replaced alternators they have not been supplied with the pulley. You have to take the pulley off the old one and swap it over. Can be fun getting the nut off sometimes! I believe RTC5686 is the part number for the pulley but check the parts book to be sure. Quote Link to comment Share on other sites More sharing options...
roamingyak Posted June 13, 2019 Author Share Posted June 13, 2019 28 minutes ago, Retroanaconda said: In the past when I've replaced alternators they have not been supplied with the pulley. You have to take the pulley off the old one and swap it over. Can be fun getting the nut off sometimes! I believe RTC5686 is the part number for the pulley but check the parts book to be sure. Thanks, though at about 120 quid with South African tax it’s a bloody expensive piece of plastic!!! Quote Link to comment Share on other sites More sharing options...
mickeyw Posted June 13, 2019 Share Posted June 13, 2019 A quick look a their site, and I can see the suffix letters refer to the brand. 2 things stand out to me: STC234.C8 (note no G in the code) is a Britpart item. The 2 year warranty is also a Britpart thing. I would suggest the STC234G.C8 also comes from them. The fact that they can often supply genuine LR packaged branded parts makes it hard to choose which of their parts you can trust. 1 Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 13, 2019 Share Posted June 13, 2019 They're steel in construction. You'd likely be able to find a pulley locally. As long as it fits the shaft, takes the right size V-belt and is roughly the right diameter then it'll work. Quote Link to comment Share on other sites More sharing options...
roamingyak Posted June 13, 2019 Author Share Posted June 13, 2019 28 minutes ago, Retroanaconda said: They're steel in construction. You'd likely be able to find a pulley locally. As long as it fits the shaft, takes the right size V-belt and is roughly the right diameter then it'll work. New ones are made from plastic it seems... going to use the old one, cheap local one on the reconditioned old one if it turns up tomorrow looking ok... Quote Link to comment Share on other sites More sharing options...
