Dan D90 Posted June 15, 2019 Share Posted June 15, 2019 I’m pretty sure my Frankenstein defender td5 is running a discovery fuel map, temp gauge works backwards and its very jerky at low speed. It’s a 10p engine with a non-flash ECU. 90% of my driving is around 10-30mph so I’m getting tired of the poor performance and have decided to take a punt on a replacement ECU. I know that my current ECU can be chipped but i would prefer to keep it as a backup just encase things do not go to plan! I’m looking to buy a NNN000120. Most of the ones for sale are from the discovery 15p engine so I will need to get it remapped. Does anyone on here offer a remapping service or can recommend anyone in the Warwickshire region? Thanks Dan Quote Link to comment Share on other sites More sharing options...
Lightning Posted June 16, 2019 Share Posted June 16, 2019 (edited) You are best contacting Mike at Dynachip. He knows pretty much everything about Defender ECU’s and will be able to sort you out. Also he will call out to you anywhere in the UK and is a fair bit cheaper than most others. Edited June 16, 2019 by Lightning Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 16, 2019 Share Posted June 16, 2019 If you're in the Warwickshire area, Ian at IRB Developments would be the only person I'd use. Top chap who knows his onions. He used to work for LR as a Engine and Drivetrain development engineer I believe. Quote Link to comment Share on other sites More sharing options...
Dan D90 Posted June 17, 2019 Author Share Posted June 17, 2019 Thanks, I will try them both. ALl the best Quote Link to comment Share on other sites More sharing options...
Dan D90 Posted June 30, 2019 Author Share Posted June 30, 2019 Thumbs up for Mike at Dynachip, he chiped & mapped my ECU today. Top bloke, did a great job can, not recomend him enough. Thanks Dan Quote Link to comment Share on other sites More sharing options...
