Bilko6 Posted June 17, 2019 Share Posted June 17, 2019 hi I need help 1999 110 td5 Defender I stopped for 20 min on Friday left my lights on which are all led battery flat got home charged battery replaced also measured voltage while running it read 11.7 v tried to start but just but nothing battery reading 12.8 v before . so I put a new alternator in and still reading 11.8 v help please Quote Link to comment Share on other sites More sharing options...
MR-HIPPO Posted June 17, 2019 Share Posted June 17, 2019 Welcome to the forums. So you have charged the battery and replaced the alternator? I assume that you are reading the voltage across the battery terminals? Is your battery still holding 12.8v? I am no expert, but if it were mine I would check that the main battery cables are fully connected and tight. (at both ends) Check that there is a good earth from the battery to the gearbox / chassis. Check the live terminal on the starter motor to make sure that everything is still properly connected and done up tight. (the main battery +, and live feed from the alternator connect here) Quote Link to comment Share on other sites More sharing options...
Bilko6 Posted June 18, 2019 Author Share Posted June 18, 2019 Checked everything .I am now thinking that the 2 small wires at the back of the alternator are the problem I think that the alternator in being told not to put out the voltage if that's makes sense to anybody Quote Link to comment Share on other sites More sharing options...
Escape Posted June 18, 2019 Share Posted June 18, 2019 If the small wire for the charge warning lamp isn't connected, the alternator will (usually) not charge. Do you have the warning light on the dash with engine running? If not, does it come on during the bulb check? A broken bulb is the same as no connection. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 18, 2019 Share Posted June 18, 2019 It will start charging normally if you rev the engine, it will self-excite. If just left to idle after starting it most likely won't. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted June 18, 2019 Share Posted June 18, 2019 I had a similar problem caused by the cable corroding inside the battery terminal. I ended up replacing both cable and terminal. Mike Quote Link to comment Share on other sites More sharing options...
