Simon_CSK Posted June 22, 2019 Share Posted June 22, 2019 I have been trying to do an engine swap on my P38 and one thing has led to another. I am now also removing the gearbox so hopefully I can get the torque convertor on in the vertical position as the horizontal wiggle and turn just isn't working. Have jacked it up and have removed the props however when I jacked the front and tried to turn the wheel it was locked solid this makes me think that the bad news is my viscous coupling is seized. Can someone confirm my worst thoughts? When I jacked up the rear axle at the same time I could turn the wheels easily. The next part of this is the transfer box. I have a transfer box from an early (Gems) P38 mine is a Thor. I know the gearboxes changed but never heard anything about the transfer box is it the same transfer box or at least the same viscous coupling? I have an early gearbox and transfer box that I samed from a P38 I broke up many years ago so hopefully I can fit and forget. Help appreciated. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 22, 2019 Share Posted June 22, 2019 You have to stand on a breaker bar to make the front wheel turn, it will appear to be locked solid..... It will move smoothly, slowly. Quote Link to comment Share on other sites More sharing options...
SteveG Posted June 23, 2019 Share Posted June 23, 2019 I’m pretty sure that all BW’s are the same. Quote Link to comment Share on other sites More sharing options...
