Sign in to follow this
Chicken Drumstick
Rear spring plates/lower shock mount
Have managed to shear off the lower rear shock mount on the spring plate. Looks like I may need to perform some R&D. Although it has lasted a good number of years since modding my 88.
Can anyone help locate any of these? I’m assuming they are not remanufactuered at present.
As il struggling to find them.
I can find a couple of different spring plates listed for the front axle. Anyone know how these differ to the rear or if they can be substituted?
Share this post
Link to post
They are being remade, I'm sure.
Share this post
Link to post
Grind off what is left of the pin and weld on a 19mm bolt.  You will never have problems with the bushes failing
Peter
Share this post
Link to post
Thanks. Haven't had an issue with bushes though. The plate has sheared off diagonally along the bottom crossing over one of the U bolt holes.
Share this post
Link to post
