ThreeSheds Posted June 25, 2019 Share Posted June 25, 2019 Impressed! This thing easily undid my very rusty 16 year old brake pipe union... This is the one I bought, but obviously you may be able to find it cheaper or better! 1 Quote Link to comment Share on other sites More sharing options...
western Posted June 25, 2019 Share Posted June 25, 2019 Do you have a website link please, as others may like to add one of these to their tool stash Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted June 25, 2019 Author Share Posted June 25, 2019 3 minutes ago, western said: Do you have a website link please, as others may like to add one of these to their tool stash Edited to show link... 1 Quote Link to comment Share on other sites More sharing options...
lo-fi Posted June 25, 2019 Share Posted June 25, 2019 That's really quite a cunning design, thanks for posting Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 25, 2019 Share Posted June 25, 2019 Thank you, this is really one of my pet hates on a car. Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted June 25, 2019 Author Share Posted June 25, 2019 A couple of rubishy videos of it in use.... here and here (not sure if the links worked... but we'll soon find out! 1 Quote Link to comment Share on other sites More sharing options...
Blanco Posted June 26, 2019 Share Posted June 26, 2019 Worked well, we can see how it grips, ..... any permanent damage to the wing or the teeth??! Quote Link to comment Share on other sites More sharing options...
Ex Member Posted June 26, 2019 Share Posted June 26, 2019 Looks nice. I see they do a 5 piece kit with different sized on each end. https://www.sealey.co.uk/product/5637204732/brake-pipe-spanner-set-4pc-ratcheting https://www.rapidonline.com/sealey-vs0343-flare-nut-spanner-set-4pc-ratcheting-89-6987 Quote Link to comment Share on other sites More sharing options...
MR-HIPPO Posted June 26, 2019 Share Posted June 26, 2019 Excellent, added to my wish list. Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted July 1, 2019 Author Share Posted July 1, 2019 The tale takes a new twist... Yesterday I did some more work on the brakes... and soon found a flare-nut that the new spanner didn't work on. Subsequent investigation showed that it was a 10mm nut. Bugger! So I went round and checked the others, and it seems I have multiple 11mm, a few 10mm and one 9mm (yes nine!) This on e '53 Disco. I think that the 11mm and 10mm might be original and the 9mm is a bit of a patch repair... Luckily I can cut out the b'stard sized ones since I am replacing those pipes with n-i-i-ice Cunifer ones... But if you work on old cars then maybe you should get a set because I can tell you that the 11mm spanner will not even look at a 10mm nut Roger Quote Link to comment Share on other sites More sharing options...
