Hybrid_From_Hell Posted June 26, 2019 Share Posted June 26, 2019 4 bolt PAS steering box .... Last year it started to leak, .... I fitted a new seal kit, .... hasn't lasted 5 minutes !! .., so the shaft has had it and I need a completely new unit If new who / where are the best to get, prices ?? if Reconditioned same question ? Thanks Quote Link to comment Share on other sites More sharing options...
Gazzar Posted June 26, 2019 Share Posted June 26, 2019 Speedisleeve any use? Or is it beyond that. Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted June 26, 2019 Share Posted June 26, 2019 I read somewhere that these aren't made new any longer ! When Mo needed one a while back he was told Britpart was the only official source as Adwest weren't selling to anyone else at the time... If you can get one, it may be Britpart, with Adwest on the stamp, but no telling what the final quality may be.... Paddocks are advertising new.... Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 26, 2019 Share Posted June 26, 2019 £786 ! 😨😲 Quote Link to comment Share on other sites More sharing options...
Rightfoot Posted June 27, 2019 Share Posted June 27, 2019 As someone who worked for Adwest about 20 years ago, I know that about one third of all Adwest recon boxes failed within twelve to eighteen months. Fundamentally once you have wear on the sector shaft then the box will always leak again. I don't know if anyone is machining up new sector shafts etc., but I would put money on the failure rate of recon boxes nowadays being just the same as it was. Mind you looking at the prices its probably worth going recon and hoping you get one of the two thirds that doesn't fail! 1 Quote Link to comment Share on other sites More sharing options...
Eightpot Posted June 27, 2019 Share Posted June 27, 2019 Haven't used them but a guy from D&A Steering Ltd in Birmingham visited my workshop once a few years ago, pricelist looked good and they're still going which is usually a good sign.. Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted June 27, 2019 Share Posted June 27, 2019 nissan patrol............... Quote Link to comment Share on other sites More sharing options...
Jon White Posted June 28, 2019 Share Posted June 28, 2019 Zeus seal kit. Works well as it puts the seal against a different part of the shaft so works around the worn shaft. I had one in mine for years before I did the P38 conversion. 1 Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted June 28, 2019 Share Posted June 28, 2019 10 hours ago, RedLineMike said: nissan patrol............... The whole rusting vehicle or use the steering box as an alternative? Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted June 28, 2019 Share Posted June 28, 2019 1 hour ago, V8 Freak said: The whole rusting vehicle or use the steering box as an alternative? steering box as an alternative Some fab work needed to fit it, but on the whole its a better box than anything LR produces Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted June 28, 2019 Share Posted June 28, 2019 Just had a look and they do look similar.... Like you say, some fab work to bring the location points out from the chassis rails but other than that connections wouldn't be too hard ! Quote Link to comment Share on other sites More sharing options...
Daan Posted July 1, 2019 Share Posted July 1, 2019 P38, no question. The standard ball joint fits, the spline to the steering shaft fits, or at least can be made to fit with standard parts, and last but not least, it is Land rover approved: https://www.bing.com/images/search?view=detailV2&id=F7E22AB4B1C8662A8AFA42F844A95E79ED7CEBB0&thid=OIP.tllfotafEkoLfYUKaAdcygHaE8&mediaurl=https%3A%2F%2Fs3.amazonaws.com%2Fthe-drive-staging%2Fmessage-editor%2F1516212972810-lr_classic_defender_worksv8_170118_21.jpg&exph=1280&expw=1920&q=defender+70th+anniversary+edition&selectedindex=155&adlt=strict&ajaxhist=0&vt=0&eim=1,2,6 What I am planning to do on mine. Daan Quote Link to comment Share on other sites More sharing options...
darthdicky Posted July 8, 2019 Share Posted July 8, 2019 Any idea what other works/parts are required to fit one of those Daan? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted July 8, 2019 Author Share Posted July 8, 2019 Oooooooooooooooooo any more info ? Quote Link to comment Share on other sites More sharing options...
Daan Posted July 8, 2019 Share Posted July 8, 2019 The bolt pattern is obviously different from the standard box, but with some fabwork that should be ok. On the 70th anniversary, it looks like there is a spacer plate to bolt between the box and chassis. I have never seen a 70th anniversary Landy, so I am guessing. The orientation is different on the P38, so the idle shaft sits outside the chassis rail, as opposed to inside the rail for the defender. I have got a LHD p38 box for this reason, so the idler shaft sits again on the inside (of a RHD vehicle). I can post a picky tonight if you like. Plan is to fit the box over the winter months, hopefully for my landy to be used again next summer. Daan Quote Link to comment Share on other sites More sharing options...
Jon White Posted July 8, 2019 Share Posted July 8, 2019 I have P38 steering on my series Nigel 😉 Quote Link to comment Share on other sites More sharing options...
Maverik Posted July 9, 2019 Share Posted July 9, 2019 Hmmm the pas box on the 70th isnt the same as the box pictures above... just from comparing the pictures. Quote Link to comment Share on other sites More sharing options...
Maverik Posted July 9, 2019 Share Posted July 9, 2019 Bearmach are now selling sector shafts which is a bit of a game changer for me, those boxes arent particularly difficult to rebuild. https://bearmach.com/steering-box-shaft-rtc4398 2 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted July 9, 2019 Share Posted July 9, 2019 2 hours ago, Maverik said: Hmmm the pas box on the 70th isnt the same as the box pictures above... just from comparing the pictures. The 70th is a P38 box I believe. Quote Link to comment Share on other sites More sharing options...
Daan Posted July 9, 2019 Share Posted July 9, 2019 It looks the same (granted the casting number is different). https://www.ebay.co.uk/itm/FREE-FITTING-Range-Rover-P38-1994-to-2002-2-5-TD-Remanufactured-Steering/262109818042?fits=Plat_Gen%3AMK+II&hash=item3d06f66cba:g:S48AAOSwabhUVKWf Anyone on here has a 70th anniversary defender to have a look at? 1 Quote Link to comment Share on other sites More sharing options...
Snagger Posted July 11, 2019 Share Posted July 11, 2019 The P38 input shaft splines are the same as on the Adwest box, I think. Certainly, the P38 lower column UJ fits a Defender upper column perfectly. Quote Link to comment Share on other sites More sharing options...
paintman Posted July 30, 2019 Share Posted July 30, 2019 (edited) Another vote for speedisleeve. Did mine (RRC) last year & used the blue coloured seal & to date not a drop. 31.75mm sleeve & you will need a suitable sized bit of tube to tap it into place. Dieseldog did a good writeup which is what I followed but photobucket have stolen the photos. Edited July 30, 2019 by paintman 1 Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted August 1, 2019 Share Posted August 1, 2019 The adwest recon boxes now have a phosphor bronze sleeve that loses the crappy bottom bearing, they are machined to take a deeper oil seal as well - hence the huge price...no idea if they work I buy them form C&D motor factors in Bridgwater for about 200notes, recon (but not by adwest) and don't usually have issues Quote Link to comment Share on other sites More sharing options...
