sotal Posted June 30, 2019 Share Posted June 30, 2019 I posted before on here about my clutch pedal not moving and it was suggested that I spray the pivot with penetrating oil. It has taken me this long to even take a look at it! Having had a little look am I correct in thinking that the pivot is underneath a cover in the engine bay? It looks to me like I need to remove the straight headed screws (6 of them I think) on the cover to see the pivot. Is that correct? If so is it safe to do so? I take it nothing will spring out? Thanks Quote Link to comment Share on other sites More sharing options...
rtbarton Posted June 30, 2019 Share Posted June 30, 2019 No problem, it's just a cover, it doesn't hold anything in place. Quote Link to comment Share on other sites More sharing options...
sotal Posted June 30, 2019 Author Share Posted June 30, 2019 19 minutes ago, rtbarton said: No problem, it's just a cover, it doesn't hold anything in place. Great - so the pivot is under there? Whip that off and give it a spray? Quote Link to comment Share on other sites More sharing options...
lo-fi Posted June 30, 2019 Share Posted June 30, 2019 You can see either side of the pivot pin outside the pedal box too, so attack it with penetrating fluid wherever you can. Quote Link to comment Share on other sites More sharing options...
