Simon_CSK Posted July 5, 2019 Share Posted July 5, 2019 Been staring at this for a number of years. The door handle on my P38 broke, litterally pulled off the car when I tried to open it. Spent some time this morning and realised just haw easy it was to fix. The plastic pin on the handle which bears on the camb had worn away to a point. I simply drilled through it and put a hex bolt and a couple of nuts on it to secure it in the correct place. 1 Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted July 6, 2019 Share Posted July 6, 2019 On 7/5/2019 at 11:17 AM, Simon_CSK said: Been staring at this for a number of years. The door handle on my P38 broke, litterally pulled off the car when I tried to open it. Spent some time this morning and realised just haw easy it was to fix. The plastic pin on the handle which bears on the camb had worn away to a point. I simply drilled through it and put a hex bolt and a couple of nuts on it to secure it in the correct place. Hi Simon , remember the door handle that you sent me ? exactly the same problem & they are still making these in plastic 😉 Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted July 6, 2019 Author Share Posted July 6, 2019 Actually Paul when I went to fit it on the handle I had put on the car as a temporary fix had a perfect drivers door handle but the lock was wrong so I was able to take the handle off and put it on my old lock. Am currently working my way through major and minor issues so should have my car on the road this week. Hopefully then be able to take it to the British Grand Prix. Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted July 7, 2019 Share Posted July 7, 2019 14 hours ago, Simon_CSK said: Actually Paul when I went to fit it on the handle I had put on the car as a temporary fix had a perfect drivers door handle but the lock was wrong so I was able to take the handle off and put it on my old lock. Am currently working my way through major and minor issues so should have my car on the road this week. Hopefully then be able to take it to the British Grand Prix. If you ever find a way of changing the lock over on one of these handles let us know will you bud . Good luck with your repairs . Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted July 7, 2019 Author Share Posted July 7, 2019 13 hours ago, P38 Paul said: If you ever find a way of changing the lock over on one of these handles let us know will you bud . Good luck with your repairs . I don't think you can change the lock over but an independent told me that LR can cut a new lock for your key Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted July 8, 2019 Share Posted July 8, 2019 19 hours ago, Simon_CSK said: I don't think you can change the lock over but an independent told me that LR can cut a new lock for your key Sounds nice & expensive , I think I will stay with what I've got 😉 Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted July 8, 2019 Author Share Posted July 8, 2019 4 hours ago, P38 Paul said: Sounds nice & expensive , I think I will stay with what I've got 😉 Define expensive? I think it was a little short of £200.00 which for a Range Rover is very reasonable. Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted July 9, 2019 Share Posted July 9, 2019 21 hours ago, Simon_CSK said: Define expensive? I think it was a little short of £200.00 which for a Range Rover is very reasonable. You're correct Simon , that is cheap for a Range Rover , I wonder if you have to go through a main dealer or can a independent source the new handle & lock ? Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted July 9, 2019 Author Share Posted July 9, 2019 15 minutes ago, P38 Paul said: You're correct Simon , that is cheap for a Range Rover , I wonder if you have to go through a main dealer or can a independent source the new handle & lock ? The Independent said he could do it. Try your local Indy and see. He showed me the price on his computer. I know also there are spare keys cut at the point of manufacture these are in storage and just need coded with the EKA code. This I was told by the Indy but confirmed yesterday by an auto locksmith who was replaing my Disco key after I lost it. . Quote Link to comment Share on other sites More sharing options...
Fae Posted March 8, 2020 Share Posted March 8, 2020 STC3064 is the part number for the right hand door handle repair kit. £3 - £4 Quote Link to comment Share on other sites More sharing options...
Milanet Posted May 21, 2020 Share Posted May 21, 2020 I have recently fallen foul of this one. Ive been awaiting parts from Craddocks since February. They have finally released the order so the parts are coming tomorrow (Less the handle, they are struggling to get that one. I think they have had to liaise with Land Rover directly. Still, I am confident I`ll get it as they haven`t said No yet. I`ll try and upload a picture of the order so others can benefit from the part numbers etc. I was holding off buying the cheap fix parts as didnt want to pay the tenner postage just for the £4 bits. I suggest anyone whose Handles are getting stiff buy the cheap fix sooner rather than later. Not looking forward to doing it if I`m honest. Parts Diagram is currently available to be viewed here http://new.lrcat.com/#!/1234/88265/88266/6958 Just stumbled over this article which I`ll be following. https://rangerovers.pub/topic/360-stiff-door-handles-solved-and-painless?page=1 I`ll let you know how I get on Quote Link to comment Share on other sites More sharing options...
Milanet Posted May 22, 2020 Share Posted May 22, 2020 (edited) So. Left door done & it wasn`t too bad. Big shout out to Orangebean @ rangerovers.pub for the plastic tie tip however it was still a fiddle. Interestingly, either the chap at landrover putting the springs in the bags have either put the right door spring in the left kit bag & the left door spring in the right kit back or the part numbers are wrong for each door. I didnt end up using MTC9290 - CLIP-RETAINER PIN or ALR68 Clip. Ive added more pics below as the ones on the definitive fix are missing https://www.rangerovers.net/threads/the-definitive-fix-for-stiff-p38a-door-handles.11692/ First job was to pop off what they call a cheater panel(just pulls off). This reveals Door card securing screw no.1. Disconnect the speaker connector. Remove the screw securing the remote handle escutcheon, remove escutcheon. Two more screws under the arm rest. Then its the door card pull and jiggle (might break some clips here x12). Disconnect Speaker connector. Carefully release the plastic sheet, I used a thin knife Torch time. The Red Plastic retaining clip at the latch end just needs to be rotated anti clockwise then remove the control rod from the door handle. Torx 25 bit for the handle inner securing screw, slide the handle forwards and rotate outwards to reveal the outer securing screw. Take plenty of pics of the inner workings of the handle to give yourself a fighting chance. Put the kettle on as here comes the fun bit. Remove old roll pin and seperate the old spring and plastic bit. Then its the plastic tie trick (Swearing optional). I found thicker ties held better but the bigger they are you lose space to move. You can see where the mechanism rubs the spare bit of metal at the bottom of the handle, I just snapped mine off once it was back together again. Now I`m waiting for the drivers door handle to arrive and I`ll follow up once I`ve done that side if there are any big differences. Hope this helps. Edited May 22, 2020 by Milanet Image resized Quote Link to comment Share on other sites More sharing options...
Milanet Posted May 22, 2020 Share Posted May 22, 2020 (edited) If I don`t get the handle I`ll just use Simon_CSK fix saving me £ 80 Badabing................P38... Best car Ive ever driven, Smiles all day long Edited May 22, 2020 by Milanet didnt look right Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted May 25, 2020 Author Share Posted May 25, 2020 On 5/22/2020 at 9:28 PM, Milanet said: P38... Best car Ive ever driven, Smiles all day long Took mine for a run today to test drive it after fitting LPG and agree big smiles. I like my P38 very much but have recently addedd an L322 HSE to my collection which is so good that I am in the process of changing it to a TDV8.Range Rovers just keep getting better and better but think I need to do something about my CSK. Quote Link to comment Share on other sites More sharing options...
GD100 Posted September 26, 2022 Share Posted September 26, 2022 Hello, I happened upon this thread due to shared interest. I suffered the same issues with driver's side (left) door handle. I purchased the repair spring, lever and pin kit. While installing, I snapped off the small pot-metal pole in which the pin is supposed to fasten the plastic spring lever. Uggghhh. I found a replacement handle at pick a part for $15.00. The only issue was the lock tumbler required swapping out. After some trial and error, I discovered the trick to popping out the tumbler. When viewing the tumbler you will notice two "L" shaped latches that fit inside a reciprocal notch. These are where the tumbler is released by spinning the top section opposite the bottom. I used a crescent wrench and vice grips. However, there is one important step required for success. The key must be inserted in the tumbler and turned while you are wrenching the top and bottom. It is spring loaded and caution must be paid to avoid it blasting off and being lost or injuring someone. Hope it helps. Quote Link to comment Share on other sites More sharing options...
