Coolant Bleed Freelander 2 Diesel ‘09
VAM
About to undertake a coolant bleed on. Freelander 2, diesel 2.2 ‘09.
The workshop manual at step 13(or 14) lists a step as “connect exhaust extraction hose’ as a step towards reconnecting everything back. But don’t see this as being disconnected in the previous steps.
Any ideas what this is or if needs doing is appreciated.
Also (although the right step) is it necessary to disconnect the radiator hose to flush the radiator or (a lazy ass) coolant bleed to replace the coolant will do the job? I’ve only ever topped the (current) coolant with the coolant mix.
