grahamSX Posted July 7, 2019 Share Posted July 7, 2019 Hope someone can help D1 300 tdi black smoke under load and not boosting lucky to get 50/70 out of it all hoses been changed valve clearance's been checked Activator working when pressured oil cooler cleaned out I have a boost reading of 0.1 to 0.7 anyone know of where else to look please thank you . Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 7, 2019 Share Posted July 7, 2019 Presume the air filter is OK? Quote Link to comment Share on other sites More sharing options...
Alsace_rangie Posted July 7, 2019 Share Posted July 7, 2019 Intercooler blocked? EGR stuck wide open? Quote Link to comment Share on other sites More sharing options...
joe1 Posted July 8, 2019 Share Posted July 8, 2019 cam belt timing? Quote Link to comment Share on other sites More sharing options...
grahamSX Posted July 8, 2019 Author Share Posted July 8, 2019 (edited) On 7/7/2019 at 6:39 PM, Alsace_rangie said: Intercooler blocked? EGR stuck wide open? Nope deleted that and intercooler cleaned out Edited July 8, 2019 by grahamSX Adding bits Quote Link to comment Share on other sites More sharing options...
grahamSX Posted July 8, 2019 Author Share Posted July 8, 2019 On 7/7/2019 at 5:34 PM, BogMonster said: Presume the air filter is OK? New one fitted Quote Link to comment Share on other sites More sharing options...
grahamSX Posted July 10, 2019 Author Share Posted July 10, 2019 On 7/8/2019 at 3:46 PM, joe1 said: cam belt timing? That's my next step Quote Link to comment Share on other sites More sharing options...
Maverik Posted July 10, 2019 Share Posted July 10, 2019 Yeah I'd be checking timing next I think. Quote Link to comment Share on other sites More sharing options...
grahamSX Posted July 10, 2019 Author Share Posted July 10, 2019 A big thank you all your help on this matter I have found the problem it was the waste gate flap in the manifold 1 it was sticking and second it it rattleing in side Quote Link to comment Share on other sites More sharing options...
lo-fi Posted July 11, 2019 Share Posted July 11, 2019 Slight rattling inside is normal, the flap is loose on the mount to allow it to settle onto the seat and seal properly. Sticking is not uncommon, especially if it's driven gently most of the time and the wastegate doesn't do much. Quote Link to comment Share on other sites More sharing options...
