ThreePointFive Posted July 8, 2019 Share Posted July 8, 2019 Hi, looking for part numbers for the fixings that keep the wash/wipe switch attached to the indicator assembly. The switch itself is AMR6106R fixing to AMR6105R. NOT the right switches for these part numbers, but showing the 3 fixings i am talking about... Please note that these do not fit, I have tried. None of the Microcat-derived diagrams I can see even acknowledge there are fixings there. Any help appreciated. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted July 8, 2019 Share Posted July 8, 2019 (edited) They are just self tapping screws. The later ones like the one you posted only uses two screws. Edited July 8, 2019 by Red90 Quote Link to comment Share on other sites More sharing options...
western Posted July 8, 2019 Share Posted July 8, 2019 New wash/wipe stalks comewith the screws. at least this one does https://www.brit-car.co.uk/product.php/418782/3851/wash_and_wiper_switch_defender I suspect Tek screws would do the job. Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted July 8, 2019 Author Share Posted July 8, 2019 Thanks - Mine definitely arrived with no fixings, but I will see which ones fit in my pile of screws if they aren't meant to be a tiny bolt of some kind. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted July 8, 2019 Share Posted July 8, 2019 What happened to the existing screws? Normally you just reuse. They are no bolts. They are self tapping screws that thread into the metal. I just did one of these a week ago. The new OEM switch did not have screws. The screws from the old switch just moved over. The three screw version is the early, non intermittent style. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted July 8, 2019 Share Posted July 8, 2019 11 minutes ago, western said: New wash/wipe stalks comewith the screws. at least this one does https://www.brit-car.co.uk/product.php/418782/3851/wash_and_wiper_switch_defender I suspect Tek screws would do the job. That link is for the old style without intermittent function. 1990 and earlier. Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted July 8, 2019 Author Share Posted July 8, 2019 i'm replacing an old style switch with new to match a late Td5 wiring loom, hence only the old one to use as a reference - those are something like a 6.5mm bolt (I guess imperial, but who has time to look up the conversion...) If I can't buy the right ones, I will have to try to find the right size screw, though this is going to risk messing up the threads on my new switches. Quote Link to comment Share on other sites More sharing options...
western Posted July 8, 2019 Share Posted July 8, 2019 this is the Td5 stalk, no screws, https://www.ebay.co.uk/p/Bearmach-Land-Rover-Defender-Td5-Wiper-Switch-Stalk-98-on-AMR6106R/1825279053?iid=321773732419 Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted July 14, 2019 Author Share Posted July 14, 2019 No further forward with this one, unfortunately. All the new switches (inc. mine) are supplied without the screw and nothing I had fits. It doesn't actually appear that the hole is even threaded as far as you can see down, so unsure how it even secures. Not really sure what else I can do.... Quote Link to comment Share on other sites More sharing options...
western Posted July 14, 2019 Share Posted July 14, 2019 I was able to extract one machine screw from my wash/wipe stalk, they are 1/2 inch long from under the head, 1/4 hex socket fits, suspect the thread is imperial as its to small to be 4mm & to big to fit a 3mm thread die, Hope that helps. Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted July 14, 2019 Author Share Posted July 14, 2019 Hi Western, thanks for doing that, appreciated. Is this from the TD5-onwards stalk controls or earlier though? Quote Link to comment Share on other sites More sharing options...
western Posted July 14, 2019 Share Posted July 14, 2019 On my 1989 110, I converted to intermittent wash/wipe a few years ago, IIRC the screws were reused. Current stalk in prc7370 as on later vehicles with front intermittent wash/wipe Quote Link to comment Share on other sites More sharing options...
Ex Member Posted July 15, 2019 Share Posted July 15, 2019 As already mentioned a few times. The screws are self tapping. The holes are not threaded. The screws tap into the stalk. You use the screws that came out of the old one. I did this a few weeks ago. Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted July 15, 2019 Author Share Posted July 15, 2019 (edited) 17 hours ago, Red90 said: As already mentioned a few times. The screws are self tapping. The holes are not threaded. The screws tap into the stalk. You use the screws that came out of the old one. I did this a few weeks ago. 😖 You certainly did, several times. I clearly read what I thought you were saying - it's a couple of small screws - rather than the all important "self tapping". I will recover the old ones and be a bit braver with the ratchet once I had a suitable socket as per Ralph's post. Thank you both for the help, despite my stupidity Edited July 15, 2019 by ThreePointFive Quote Link to comment Share on other sites More sharing options...
