FridgeFreezer Posted January 19, 2020 Share Posted January 19, 2020 2 hours ago, Snagger said: It’s the type the Camel Trophy used. Worth noting the Camels had VERY full roll cages too, so the roof is taking zero load and the roof rack can be used for recovery (I've seen it demonstrated!) One thing I found is the amount of flex in the body on rough roads is astounding if you look - of course the LR body is not a very strong or rigid structure and I suspect driving around with a RTT on could easily lead to fatigue cracks after a while. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted January 19, 2020 Share Posted January 19, 2020 8 minutes ago, FridgeFreezer said: Worth noting the Camels had VERY full roll cages too, so the roof is taking zero load and the roof rack can be used for recovery (I've seen it demonstrated!) One thing I found is the amount of flex in the body on rough roads is astounding if you look - of course the LR body is not a very strong or rigid structure and I suspect driving around with a RTT on could easily lead to fatigue cracks after a while. It is the ammount of flex that is stopped by the roof rack that is the problem especially with the 110. Even the short rack on my Defender allowed the rivit to pull. I have only seen the driver side rivit pull, has anybody seen the other side pull Quote Link to comment Share on other sites More sharing options...
Snagger Posted January 19, 2020 Share Posted January 19, 2020 57 minutes ago, FridgeFreezer said: Worth noting the Camels had VERY full roll cages too, so the roof is taking zero load and the roof rack can be used for recovery (I've seen it demonstrated!) One thing I found is the amount of flex in the body on rough roads is astounding if you look - of course the LR body is not a very strong or rigid structure and I suspect driving around with a RTT on could easily lead to fatigue cracks after a while. Very good point about their roll cages. And yes, even the SII/SIII body flexes, and is much thicker and has more bracing than the late Defenders. Quote Link to comment Share on other sites More sharing options...
Vogler Posted September 2, 2021 Author Share Posted September 2, 2021 (edited) I'm just back from a long Iceland trip with a lot of miles on "bad" highland roads. I have a Hannibal roof rack with full length gutter bars, which I simply cut between the legs before my departure, so it kept the body less from flexing. Seems to have worked. Despite having driven considerably more than the previous trips with the same load, everything held up nicely. (Not mentioning the driver's door hinges and rear upper shock mount wearing out 🙄) J Edited September 2, 2021 by Vogler 2 Quote Link to comment Share on other sites More sharing options...
elbekko Posted September 3, 2021 Share Posted September 3, 2021 15 hours ago, Vogler said: I'm just back from a long Iceland trip with a lot of miles on "bad" highland roads. I think that calls for a thread in Getting Out and About with lots and lots of pictures! Quote Link to comment Share on other sites More sharing options...
Vogler Posted September 3, 2021 Author Share Posted September 3, 2021 Will do Ben. I'll have to get trough the quadrizillion photo's first. Got more pics than kilometers... I wasn't aware of that section BTW. J Quote Link to comment Share on other sites More sharing options...
