Hawklord Posted July 26, 2019 Share Posted July 26, 2019 Hi When going through villages with speed recorders the figure shown on the roadside display always appears to be lower than what my speedo shows. Can anyone tell me which colour (teeth number) speedo drive gear I should have in my 300TDI defender 90 fitted with 235/85 R16 tyres and discovery 1.2 ratio transfer box. Thanks Quote Link to comment Share on other sites More sharing options...
MR-HIPPO Posted July 26, 2019 Share Posted July 26, 2019 (edited) Here you go. Land Rover 90/110 speedo drive gears Colour: blue/20 teeth - Part number: FRC3310 - Tyres: 7.50/16 or 235/85/16 Colour: green/21 teeth - Part number: FRC3311 Colour: yellow/22 teeth - Part number: FRC3312 - Tyres: 205/16 tyres Colour: red/24 teeth - Part number: FRC3313 Taken from THIS page. Transfer box ratio does not affect this, as the speedo drive is driven from the output side of the box. Edited July 26, 2019 by MR-HIPPO Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted July 26, 2019 Share Posted July 26, 2019 With the blue one and 235/85R16 it will over-read by around 5% which is just about ideal. Transfer box ratio makes no difference. Only diff ratio and tyre size. Quote Link to comment Share on other sites More sharing options...
Hawklord Posted July 27, 2019 Author Share Posted July 27, 2019 Thanks for your replies and I have the blue 20T gear fitted so will just accept the error, but at least it reads higher. Quote Link to comment Share on other sites More sharing options...
Pappa Smurf Posted July 27, 2019 Share Posted July 27, 2019 Why would the reading be off? If they are the standard size tyres, surely it just needs calibrating. Quote Link to comment Share on other sites More sharing options...
western Posted July 27, 2019 Share Posted July 27, 2019 I wouldn't rely on those speed signs being 100% accurate. check your speedo readings against a GPS unit. I run 255/85 with a standard 110 transfer box of 1.410:1 & its very accurate when compared to my gps speed Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted July 27, 2019 Share Posted July 27, 2019 2 hours ago, Pappa Smurf said: Why would the reading be off? If they are the standard size tyres, surely it just needs calibrating. Speedos are designed to over-read slightly - usually by 5-10%. They are not allowed to under-read, so manufacturers err on the side of caution. It also gives you a useful safety margin of a few mph for those speed traps Quote Link to comment Share on other sites More sharing options...
steve b Posted July 27, 2019 Share Posted July 27, 2019 Is that with the standard drive gear Ralph? As James says the speedo should read correct or over , pretty much every vehicle I've driven with a separate GPS shows this , the closest is my Forester but that over reads by a couple of mph . One of the quirks I found driving around NZ was fairly frequent odometer check signs on the roads either a measured 1km or 10km . cheers Steve b Quote Link to comment Share on other sites More sharing options...
Pappa Smurf Posted July 27, 2019 Share Posted July 27, 2019 Fair enough, I can see the logic. Quote Link to comment Share on other sites More sharing options...
western Posted July 27, 2019 Share Posted July 27, 2019 23 minutes ago, steve b said: Is that with the standard drive gear Ralph? As James says the speedo should read correct or over , pretty much every vehicle I've driven with a separate GPS shows this , the closest is my Forester but that over reads by a couple of mph . One of the quirks I found driving around NZ was fairly frequent odometer check signs on the roads either a measured 1km or 10km . cheers Steve b Yes, in my 110 the blue frc3310 gear. Quote Link to comment Share on other sites More sharing options...
cackshifter Posted July 29, 2019 Share Posted July 29, 2019 On 7/27/2019 at 1:57 PM, steve b said: One of the quirks I found driving around NZ was fairly frequent odometer check signs on the roads either a measured 1km or 10km . Because tourist hunting is the national sport of the NZ constabulary in their unmarked Commodores Quote Link to comment Share on other sites More sharing options...
steve b Posted July 29, 2019 Share Posted July 29, 2019 I did 15000km north and south Island and never had any problems at all , back then on the south Island particularly we could drive for 2 or 3 hours and not see another vehicle , 20 years ago though . One of my favourite places and road tours so far , what would have made it even better would have been an early RRC in place of the Mitsi Mirage although it coped totally with around 7000km of dirt roads and still did high 30's mpg Saw several Series 1's and 2/2a's around cheers Steve b Quote Link to comment Share on other sites More sharing options...
