Gluv Posted July 28, 2019 Share Posted July 28, 2019 Hi Does anybody know where I could find the complete hand throttle kit for the 300 tdi defender ? I'm struggling to find anything! cheers Gluv Quote Link to comment Share on other sites More sharing options...
miketomcat Posted July 28, 2019 Share Posted July 28, 2019 The n/a version is a choke cable with a bracket and lever on the pump. I have one on ours but haven't modified it to fit the 200tdi. Mike Quote Link to comment Share on other sites More sharing options...
Gluv Posted July 28, 2019 Author Share Posted July 28, 2019 5 hours ago, miketomcat said: The n/a version is a choke cable with a bracket and lever on the pump. I have one on ours but haven't modified it to fit the 200tdi. Mike Pretty much the same for the 300 tdi Mike. There seems to be plenty of cables about but not the rest of it 🙁 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted July 28, 2019 Share Posted July 28, 2019 Here's a photo of the n/a set up. I don't think it would be that hard to make something. Must get round to it at some point. Mike Quote Link to comment Share on other sites More sharing options...
western Posted July 28, 2019 Share Posted July 28, 2019 Have a look in a 1991 defender parts book for hand throttle parts, only items in my 1987 on parts bok are for the older diesel engines, totally different parts. Quote Link to comment Share on other sites More sharing options...
steve b Posted July 28, 2019 Share Posted July 28, 2019 HOFS used a lawn mower throttle cable and control iirc on at least one of the proto race trucks with a Tdi , hopefully someone could provide you with a link? cheers Steve b Quote Link to comment Share on other sites More sharing options...
nickwilliams Posted July 29, 2019 Share Posted July 29, 2019 Back in 2010 I posted a thread on how to do this using (mostly) non-standard but available and home made parts. The pictures are here but I can't find the thread they were linked from. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 29, 2019 Share Posted July 29, 2019 @nickwilliams, this one? Quote Link to comment Share on other sites More sharing options...
PaulMc Posted July 29, 2019 Share Posted July 29, 2019 From the 'Wolf' ISPL - . Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted July 30, 2019 Share Posted July 30, 2019 I've just taken a home-made version off my 300tdi, because the cable had snapped and I can't think I'll ever use it. It's a fairly basic bracket to terminate the cable outer and a small adapter to link the cable to the lever on the pump. Quote Link to comment Share on other sites More sharing options...
Gluv Posted July 30, 2019 Author Share Posted July 30, 2019 14 hours ago, PaulMc said: From the 'Wolf' ISPL - . I have the wolf parts manual so have all the proper numbers but searching on the net has turned up nothing. I was told at craddocks that military parts are now only available to military customers. I don't know how true that is . Gluv Quote Link to comment Share on other sites More sharing options...
nickwilliams Posted July 30, 2019 Share Posted July 30, 2019 On 7/29/2019 at 12:04 PM, Bowie69 said: @nickwilliams, this one? That's the one! Quote Link to comment Share on other sites More sharing options...
Gluv Posted July 31, 2019 Author Share Posted July 31, 2019 Now if anybody can turn up all those bits , I will be a happy man 😎 Quote Link to comment Share on other sites More sharing options...
Eightpot Posted July 31, 2019 Share Posted July 31, 2019 I've probably got some of the parts, knob/cable and bracket, probably not got any engine side bits but will check tomorrow. Quote Link to comment Share on other sites More sharing options...
Gluv Posted August 1, 2019 Author Share Posted August 1, 2019 19 hours ago, Eightpot said: I've probably got some of the parts, knob/cable and bracket, probably not got any engine side bits but will check tomorrow. Let me know what you have 👍🙂 Quote Link to comment Share on other sites More sharing options...
Lightning Posted August 2, 2019 Share Posted August 2, 2019 Sadly this can’t be done on a TD5 Only option is to fit cruise control. Quote Link to comment Share on other sites More sharing options...
Gluv Posted August 3, 2019 Author Share Posted August 3, 2019 Anybody? Quote Link to comment Share on other sites More sharing options...
Eightpot Posted August 3, 2019 Share Posted August 3, 2019 I've got a hand throttle bracket, plastic cover and cable - if you want it you can have it for £12 posted. The cable for a n/a setup is quite short though - not sure how much use it will be. if I were going to rig something up on my own vehicle I would just use a solid wire type choke cable (rather than twisted cable), fit it in the existing choke holder in your steering column cowling, and make up a simple retainer bracket on the pump end for the cable sheath, with a little hinged arm for the cable inner to attach to, with a bent metal arm attached which collects the throttle arm and draws it back. Should be pretty easy to knock up with basic tools. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted August 4, 2019 Share Posted August 4, 2019 That what's on the inside of mine. It bolts to the side of gearbox tunnel tucked up under the dash. Mike Quote Link to comment Share on other sites More sharing options...
Gluv Posted August 4, 2019 Author Share Posted August 4, 2019 11 hours ago, Eightpot said: I've got a hand throttle bracket, plastic cover and cable - if you want it you can have it for £12 posted. The cable for a n/a setup is quite short though - not sure how much use it will be. if I were going to rig something up on my own vehicle I would just use a solid wire type choke cable (rather than twisted cable), fit it in the existing choke holder in your steering column cowling, and make up a simple retainer bracket on the pump end for the cable sheath, with a little hinged arm for the cable inner to attach to, with a bent metal arm attached which collects the throttle arm and draws it back. Should be pretty easy to knock up with basic tools. Hi , I will have all of that off you , thanks. pm me your payment details Gluv 🇬🇧🇬🇧 Quote Link to comment Share on other sites More sharing options...
PaulMc Posted August 5, 2019 Share Posted August 5, 2019 On 7/30/2019 at 10:23 AM, Gluv said: I have the wolf parts manual so have all the proper numbers but searching on the net has turned up nothing. I was told at craddocks that military parts are now only available to military customers. I don't know how true that is . Gluv There's not a 'kit' as such, parts have to be sourced individually. In the case of the grommet 531689 (and some of the screws and washers), you have to buy a bag of 10 AFAIK, all of these parts are available from a main dealer or Genuine Parts reseller, to anyone who orders them. Military parts have always been available from dealers (if you know the Civvy part number) - although, this may have changed. I'll check this out the next time I'm at my local dealer's parts counter. From previous experience, I would take anything John Craddock says, with a LARGE pinch of salt. . Quote Link to comment Share on other sites More sharing options...
Gluv Posted August 6, 2019 Author Share Posted August 6, 2019 I do believe I have managed to find all the parts . Thanks to all who have replied Gluv Quote Link to comment Share on other sites More sharing options...
