enen Posted August 2, 2019 Share Posted August 2, 2019 Hi Info on these early cars is a bit limited online. I need to use a steering wheel puller to get the wheel off Does anyone know what thread the two holes are that i need to attach my puller to? Thankyou Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted August 3, 2019 Share Posted August 3, 2019 Enen I am not sure that you absoutely require the puller. I am sure the wheel comes off without it. The thread will be either M8 or M10 and a metal bar with a couple of holes at the right centres and some long bolts with nuts or threaded rod will do the same job. Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted August 3, 2019 Share Posted August 3, 2019 never used a puller. just leave the nut on last thread. with bum off the seat. use all your weight and pull/wiggle. works every time. 1 Quote Link to comment Share on other sites More sharing options...
enen Posted August 4, 2019 Author Share Posted August 4, 2019 Got it off, thanks for the advice Quote Link to comment Share on other sites More sharing options...
