volvotgb Posted August 3, 2019 Share Posted August 3, 2019 Wonder if anyone can help. I am fitting a 4hp22 Auto box in a Volvo military truck. I have mounted an oil cooler for the gearbox and I want to put the oil temp sensor in the circuit somewhere. Does it go before the cooler or after ? Also, which port out of the gearbox is the flow to the cooler and which is the return ? Finally, I have the temp sensor from the disco the engine/box came out of. Is this a switch for a warning lamp or a sensor for a guage. I am hoping it is a simple switch as this will make things easier Thanks for your help Quote Link to comment Share on other sites More sharing options...
